Extralite Cyberends Barends
Extralite Cyberends Barends Black$135.00  1 Remaining
Extralite Cyberends Barends Silver$135.00  1 Remaining
Extralite's Cyberends are an even lighter version of the Ultraends, CNC-machined from a solid block of 7075 T6 aluminum using sophisticated 3D machining technology. Cyberends are an incredible 19g per piece. Extralite goes so far as to machine a taper inside the barends for an optimal balance between strength and lightness. Additional features include hard-anodized fixing bolts and laser-etched logos. Delrin plastic end plugs ensure safety and impact resistance. Cyberends are compatible with all common mountain bars that support barends.
Clamp diameter: 22.2mm
Weight
: 38g per pair
Comment on Extralite Cyberends Barends
