Extralite Black Lock Thru Axle
Sign Up For Our Newsletter
You're Signed Up!
Weight26 grams
Material7075 T6 aluminum
CompatibilityRock Shox
Fox
Extralite Black Lock Thru Axle Fox $115.00 Notify Me When Available
Extralite Black Lock Thru Axle Rock Shox $115.00  1 Remaining
Details
With the rising popularity of thru axle designs being used by nearly every major fork manufacturer, companies like Extralite have immediately filled in the niche for quality performance tuned parts that many discerning cyclists desire. With this in mind, Extralite has produced the Black Lock, a surprisingly lightweight thru axle skewer. Utilizing a unique externally tapered surface and precise dimensioning, Extralite is capable of shaving as many grams as possible while still maintaining a sturdy design that’s tough enough to withstand the abuse of a typical mountain bike ride. To ensure proper installation that’s as smooth as possible, each Black Lock comes with a self lubricating brass washer that is designed to reduce friction between the skewer and fork.
Each Black Lock skewer is simply installed like your typical OEM skewer, using a 6 mm allen wrench at a torque rating of 10 Nm. It is highly recommended that threads are greased prior to installation to ensure a proper torque rating.
