Specifications| Weight | 276 grams |
| Diameter | 45 mm |
| Length | 114 mm |
Maximum Output | 975 lumens | | Emitter | 3 LED Cree XPG |
| Battery | 7800 mAh lithium ion |
| Charge Time | 12 hours |
| Settings | Burn Time |
| Flash | ----- |
| Low | 24 hours |
| Medium | 10 hours |
| High | 3 hour |
Contents
Toro Light Unit
Wall-mount and USB-Compatible Smart Charger
QR Handlebar Bracket
Soft Travel/Storage Case
Instruction Manual
UK-based Exposure Lights designs some of the most compact, powerful, and lightweight lighting systems on the planet. Exposure, using the latest LED technology, has a reputation for constantly refining existing designs and increasing light intensity while staying competitive in price.
Exposure's third generation Toro unit, an extremely powerful handlebar-mounted light, features their signature glossy black anodized CNC machined, waterproof casing. The Toro's cable-free design allows for freedom of movement usually inhibited by other manufacturers' bulky external battery designs. Three powerful LEDs, enahanced with Exposure's collimated lens technology, allow for a power output of nearly a thousand lumens!
Exposure lights function on a simple single button system. A double click activates the light, and single clicks afterward cycle through high, medium, and low settings. Holding the button for one second cycles into high visibility flashing mode, and a two second hold turns the unit off. Additionally, the LED-backed button functions as a fuel gauge, with constant feedback on remaining battery life.
The Toro features Exposure's "Smart Port" technology, which utilizes a single gold-plated port for charging and accessory use. Available accessories include:
Remote Switch
Piggyback Battery
Boost Cable
The Toro is designed to be mounted on the handlebars. The included bracket includes shims to mount on diameters of 31.8, 26.0, or 25.4 mm. The bracket mounts securely with a single M5 bolt, and the light unit attaches with an ingenious quick release system that is equally secure and convenient.
Links
For trail riding at night, we highly recommend using both helmet- and handlebar-mounted lights. Exposure's Toro and Diablo
lights are designed with the same light output and beam pattern, and work well when paired together.
