Exposure Helmet Mount
 1 Remaining
$30.00
Add to Cart:
Weight12 grams
Exposure's lightweight helmet mount fits though the vents of a helmet, secured by brackets on the interior and exterior of the shell, and is designed to work with Exposure's Diablo, Joystick, and Spark lights. The light is easily installed and removed from the bracket's plasic clip, which articulates on a ball joint to allow proper beam positioning. Use of the light's lanyard is highly recommended to secure it to the helmet so that it is not lost in the event of a crash.
Two different length nylon M6 bolts are included to maximize helmet model compatibility. A 5 mm hex wrench is required to tighten the nylon bolt.
