ESI Grips, Racer's Edge
ESI Grips, Racer's Edge Black$18.00 In Stock
ESI Grips, Racer's Edge Blue$18.00 In Stock
ESI Grips, Racer's Edge Green$18.00  2 Remaining
ESI Grips, Racer's Edge Orange$18.00  1 Remaining
ESI Grips, Racer's Edge Red$18.00 In Stock
ESI Grips, Racer's Edge White$18.00 In Stock
ESI Grips, Racer's Edge Yellow$18.00  2 Remaining
Weight50 grams per pair
Length132 mm
Outer Diameter28 mm
The popularity of our best-selling ESI grips is based on several factors. The vibrant colors are easy to clean, and the long-lasting tough silicone material doesn't become sticky when exposed to extensive sunlight. Additionally, these grips achieve a respectable light weight without compromising functionality. The consistency of the material and diameter make them ideal for trimming to shorter lengths where necessary.
Racer's Edge
Of ESI's two grip options, the Racer's Edge is lighter and thinner - an ideal choice for the weight conscious, aggressive racer. For a slightly heavier, more comfortable grip, try ESI's Chunky Grips.
ESI grips are designed to fit tightly for maximum security and rider safety. To ease installation, we recommend lightly coating the inner diameter of the grip with isopropyl alcohol prior to installation. The alcohol acts as a lubrication that will quickly evaporate once the grip is installed.
Comment on ESI Grips, Racer's Edge
