Enve Smart System 6.7 Tubular Rims
Enve Smart System 6.7 Tubular Rims 60 mm Front, 20 Hole$875.00 Notify Me When Available
Enve Smart System 6.7 Tubular Rims 70 mm Rear, 24 Hole$875.00 Notify Me When Available
Enve Smart System 6.7 Tubular Rims Decal Upgrade Metallic Red$60.00  2 Remaining
Enve Smart System 6.7 Tubular Rims Decal Upgrade White$60.00  2 Remaining
Weight, Front455 grams
Weight, Rear485 grams
Width, Front26 mm
Width, Rear24 mm
Depth, Front60 mm
Depth, Rear70 mm
Available Drillings20/24 hole only
Tire Compatibility28" tubular
ERD, Front535 mm
ERD, Rear517 mm
For the development of their 6.7 wheel system, Enve teamed up with aerodynamics expert Simon Smart to help produce the absolute fastest bicycle wheels on the market today. These tubular, full carbon fiber rims were fully optimized in extensive wind tunnel testing for the best aerodynamic response and stability in real world conditions. The resulting front and rear specific deep section rims feature two separate profiles; the front slightly wider and slightly shallower than the rear. The Smart System rims were designed to interface with both the active rider and various modern frame designs. Additionally, Enve heavily focused on wheel stability in varying wind conditions to ensure efficiency and rider safety.
In just a few short years, Enve has emerged as one of the industry's "heavy hitters," and has used the full capability of their engineering and manufacturing prowess to bring the design of the 6.7 Smart System wheels to life. The result of their efforts is a pair of incredibly stiff and strong, yet reasonably lightweight and incredibly FAST rims. Using their proprietary molded spoke hole design, Enve ensures maximum strength at the spoke-rim interface while allowing higher spoke tensions that improve wheel reliability. The 6.7 series rims also feature an all new textured sidewall design that improves braking response and thus rider safety. In a departure from their traditional bold decaling, Enve has chosen understated and elegant black decals that vary in appearance depending on light conditions.
Enve Composites is an American company committed to American design, engineering, and manufacturing. Enve 6.7 rims are produced with pride in Ogden, Utah, USA.
Each rim purchase includes Pillar internal spoke nipples, an Enve valve extender, and a pair of Enve's proprietary brake pads.
Ordering
Available exclusively through Fair Wheel Bikes - custom colored Enve decals! To order your custom decal set, simply purchase a decal upgrade for each rim set purchased. Each decal upgrade includes 12 decals for a front and rear rim set. Decals are not available separate from rim purchases. Rims are shipped with decals applied. Standard rims include the stock black and white Enve Smart System decal.
Assembly
We recommend that wheels built with Enve 6.7 rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly or submit a custom wheel build request here.
Links
VeloNews: Game Changer - Smart Enve 6.7 Rims and Wheelsets
CyclingNews: Enve Wheels - Can "Aero" Get Any Quicker?
Comment on Enve Smart System 6.7 Tubular Rims
