Enve M50 Fifty Carbon 29" Rim
$999.00
SKU:
6364
In the last few years ENVE Composites has become the standard by which the worth of all other carbon cycling components are weighed against, and it seems that few can compare. In the same spirit of creating an exceptional product that withstands the needs and abuse of not just pros, but amateurs alike, Fair Wheel Bikes is proud to introduce the latest iteration of mountain bike technology, the ENVE M Series.
Designed to accommodate the precise style of each individual rider, ENVE has created 4 specific classes of rims that appeal to 4 totally different styles of riding. Each model is given a name that represents the ratio between ascending vs. descending that each rim was designed to ideally accommodate. What this amounts to is a rim profile that is optimized for a range of tire sizes that are specific to the intended riding style, thus resulting in desirable handling characteristics.
All the ability to dial in your ride experience comes at no performance penalty. In fact, each rim in the M Series is lighter, stiffer, and more durable than their comparable predecessors due to improved rim shape, and differing laminates for each style of rim.
Beadless Tire Retention
By eliminating the "hooked" sidewall from the rim, ENVE was able to create a more reliable tire interface. By insuring a more precise fit, riders are able to run lower tire pressures safely and with confidence. According to ENVE, the new interface is stronger and less prone to burping and pinch flats.
M-Series 50Fifty
ENVE's cross country specific rim designed to get you through long hours and rough terrain on race day. Defined by vertical compliance and its ability to reduce rider fatigue. For the race minded individual who is climbing as often as they are descending.
Tire CompatibilityUST Tubeless
Comes WithNipples
Valve Stem
Tubeless Rim Strip
50Fifty
Weight330 grams
Depth28 mm
Outer Width27 mm
Inner Width21 mm
Tire Size1.9-2.25"
ERD601
