Enve Composites
Enve / Soul-Kozak Limited Edition Wheelset
Specifications Weight~1410 grams Front HubSoul Kozak 2012 Aero Rear HubSoul Kozak 2012 SpokesSapim CX-Ray black and white RimsEnve 45 clincher...
$2,290.00
2 options.View
Enve / Tune Smart System 6.7 Wheelset
Specifications Weight1380 grams Front HubTune Mig 70 Rear HubTune Mag 170 SpokesSapim CX-Ray, black RimsEnve 6.7 Smart System Spoke Count20 front,...
$2,582.00
2 options.View
Enve 1.0 Road Fork
Specifications Weight, Uncut Steerer295gr. Steerer Tube O.D.1 1/8" Axle to Crown367 mm Rake43 mm About Enve Composites In late 2010, Edge...
$489.00
1 in stock.View
Enve 1.25 / Extralite SX Tubular Wheelset
Weights: front: 390 grams rear: 500 grams total: 880-890 grams complete.
$2,390.00
2 options.View
Enve 1.25 Carbon Tubular Rim
Specifications Weight260 grams Width21 mm Depth25 mm Available Drillings20, 24, 28 hole Tire Compatibilitytubular, 28" ERD607 mm About Enve...
$780.00
12 options.View
Enve 1.45 Carbon Tubular Rim
Specifications Weight295 grams Width21.5 mm Depth45 mm Available Drillings20, 24 hole Tire Compatibilitytubular, 28" ERD564 mm About Enve...
$780.00
12 options.View
Enve 1.65 Carbon Tubular Rim
Specifications Weight360 grams Width21.5 mm Depth65 mm Available Drillings16, 20, 24, 28 hole Tire Compatibilitytubular, 28" ERD527 mm About Enve...
$780.00
11 options.View
Enve 2.0 Road Fork
Specifications Weight, Uncut Steerer350 grams Steerer Tube OD1 1/8" Axle to Crown367 mm Rake43mm About Enve Composites In late 2010, Edge...
$389.00
0 in stock.View
Enve 25mm Offset Carbon Seatpost
Specifications Weight~195 grams Available Diameters27.2, 30.9, 31.6, 34.9 mm Full Length400 mm Useroad and cross country About Enve Composites In...
$275.00
3 options.View
Enve 26" XC Tubular Rim
Specifications Weight235 grams Width24 mm Depth32 mm Available Drillings24, 28, 32 hole Tire Compatibility26" tubular ERD533 About Enve Composites...
$780.00
3 options.View
Enve 26" XC UST Tubeless Rim
Specifications Weight350 grams Width24 mm Depth32 mm Available Drillings28, 32 hole Tire Compatibility26" clincher (ISO 559), 26" UST ERD533 About...
$860.00
2 options.View
Enve 29" XC Tubular Rim
Specifications Weight290 grams Width24 mm Depth32 mm Available Drillings28, 32 hole Tire Compatibility29" tubular ERD595 mm About Enve Composites...
$875.00
2 options.View
Enve 29" XC UST Tubeless Rim
Specifications Weight385 grams Width24 mm Depth32 mm Available Drillings28, 32 hole Tire Compatibility29" clincher (ISO 622), 29" UST ERD595 About...
$890.00
2 options.View
Enve 45 Carbon Clincher Rim
Specifications Weight450 grams Width21.5 mm Depth45 mm Available Drillings18, 20, 24, 28 hole Tire Compatibilityclincher, 700c (ISO 622) ERD564 mm ...
$875.00
13 options.View
Enve 65 Carbon Clincher Rim
Specifications Weight485 grams Width21.5 mm Depth65 mm Available Drillings16, 20, 24, 28 hole Tire CompatibilityClincher, 700c ERD527 mm About Enve...
$875.00
11 options.View
Enve Carbon Compact Road Bars
Specifications Weight, 40cm210 grams Weight, 42cm215 grams Weight, 44cm220 grams Drop127 mm Reach79 mm Stem Clamp31.8 mm Detail Enve's compact...
$350.00
3 options.View
Enve Carbon Road Bars
Specifications Weight, 42cm205 grams Drop144 mm Reach85 mm Stem Clamp31.8 mm Detail Enve's road handlebar design focuses on strength and comfort...
$350.00
5 options.View
Enve Cyclocross Fork
Specifications Weight, Uncut Steerer450 grams Steerer Tube O.D.1 1/8" Axle to Crown395 mm Rake47 mm About Enve Composites In late 2010, Edge...
$529.00
1 in stock.View
Enve Downhill Mountain Handlebar
Specifications Weight225 grams Width800 mm Sweep9 degrees Rise23 mm Clamp Diameter31.8 mm About Enve Composites In late 2010, Edge Composites...
$175.00
0 in stock.View
Enve Riser Mountain Handlebar
Specifications Weight185 grams Materialcarbon fiber Stem Clamp31.8 mm Width700 mm (27.5") Back Sweep9 degrees Up Sweep5 degrees Rise20 mm About...
$160.00
0 in stock.View
Enve Smart System 3.4 Rims
Specifications Weight, Front355 grams Weight, Rear380 grams Width, Front26 mm Width, Rear24 mm Depth, Front35 mm Depth, Rear45 mm Available...
$975.00
4 options.View
Enve Smart System 6.7 Rims
Specifications Weight, Front455 grams Weight, Rear485 grams Width, Front26 mm Width, Rear24 mm Depth, Front60 mm Depth, Rear70 mm Available...
$975.00
4 options.View
Enve Sweep Mountain Handlebar
Specifications Weight175 grams Width700 mm (27.5") Sweep9 degrees Rise0 Detail We believe Enve Composite's mountain handlebars are a bit overbuilt...
$160.00
0 in stock.View
Enve Valve Extender
Specifications Weight, 39 mm2.1 grams Weight, 55 mm3.1 grams Detail These original replacement valve extenders from Enve are designed to fit their...
$8.00
2 options.View
Enve Zero Offset Carbon Seatpost
$275.00
4 options.View
Enve Carbon Brake Pads
Specifications Weight, Shimano9 grams per pair Weight, Campagnolo11 grams per pair Detail These original replacement brake pads from Enve...
$26.00
2 options.View
Enve Carbon Stem
Specifications Weight, 75 mm110 grams Weight, 90 mm115 grams Weight, 100 mm120 grams Weight, 110 mm125 grams Weight, 120 mm130 grams Weight, 130...
$265.00
7 options.View
