Enve Carbon Road Bars
Enve Carbon Road Bars 36cm$350.00 Notify Me When Available
Enve Carbon Road Bars 38cm$350.00  1 Remaining
Enve Carbon Road Bars 40cm$350.00  1 Remaining
Enve Carbon Road Bars 42cm$350.00  1 Remaining
Enve Carbon Road Bars 44cm$350.00  1 Remaining
Weight, 42cm205 grams
Drop144 mm
Reach85 mm
Stem Clamp31.8 mm
Enve's road handlebar design focuses on strength and comfort rather than absolute ultralight weight, and is equipped with several innovative design features. The bar is double grooved on the underside for easy cable routing, features a semi-flat hand section on top and a subtle ergo bend. Additionally, Enve makes use of textured non-slip sections at the stem and lever mounting positions. This bar also features integrated rubber bar end plugs that effectively prevent bar tape from unraveling.
Comment on Enve Carbon Road Bars
