Enve Carbon Compact Road Bars
Enve Carbon Compact Road Bars 40 cm$350.00 Notify Me When Available
Enve Carbon Compact Road Bars 42 cm$350.00  2 Remaining
Enve Carbon Compact Road Bars 44 cm$350.00  1 Remaining
Weight, 40cm210 grams
Weight, 42cm215 grams
Weight, 44cm220 grams
Drop127 mm
Reach79 mm
Stem Clamp31.8 mm
Enve's compact carbon road handlebar is equipped with the same thoughtful design features as their standard road handlebar, but in a slightly smaller package. Compared to its predecessor, the compact bar has a 6 mm shorter reach and a 17 mm shallower drop. The resulting geometry finds itself useful under the hands of various riders; from sprinters to cyclocross riders, or those who simply prefer more useable and/or comfortable riding positions.
Enve's road handlebar design focuses on strength and comfort rather than absolute ultralight weight, and is equipped with several innovative design features. The bar is double grooved on the underside for easy cable routing, features a semi-flat hand section on top and a subtle ergo bend. Additionally, Enve makes use of textured non-slip sections at the stem and lever mounting positions. This bar also features integrated rubber bar end plugs that effectively prevent bar tape from unraveling.
Comment on Enve Carbon Compact Road Bars
