Enve Carbon Brake Pads
$26.00
These original replacement brake pads from ENVE Composites are designed specifically for use with ENVE's line of carbon road rims. The pad compound was formulated and tested by ENVE to optimize braking performance in modulation, stopping power, and wet weather performance while managing heat build up and minimizing abrasion while extending pad wear life.
When using non-locking brake pad holders, DO NOT apply the brakes while simultaneously rotating the wheel backwards. This may result in ejection of the brake pad resulting in serious harm, accident, bodily injury or death. These pads are designed only for use with ENVE carbon road rims and should never be used with aluminum rims.
Ordering
Please note that the black brake pads are designed for new Enve rims with the textured brake surface. Usage of the grey pads on textured brake surface rims is not recommended as the softer compound will wear considerably faster but will not void the warranty. With older style rims without the textured braking surface only grey pads should be used as the harder compound of the black pads will have a significant detrimental effect on brake performance. If you have any questions on which option is correct for you please contact us and we shall help sort out any issues.
These pads are sold in pairs for one brake caliper. Please note that pads are included with new ENVE rims and wheels. Campagnolo style pad holders are compatible with current Campagnolo brakes as well as those manufactured in 2000-2010.
Weight, Shimano 9 grams per pair
Weight, Campagnolo 11 grams per pair
