Enve Carbon Brake Pads
Enve Carbon Brake Pads Campagnolo$26.00 In Stock
Enve Carbon Brake Pads Shimano$26.00 Notify Me When Available
Weight, Shimano9 grams per pair
Weight, Campagnolo11 grams per pair
These original replacement brake pads from Enve Composites are designed specifically for use with Enve's line of carbon road rims. The pad compound was formulated and tested by Enve to optimize braking performance in modulation, stopping power, and wet weather performance while managing heat build up and minimizing abrasion while extending pad wear life.
When using non-locking brake pad holders, DO NOT apply the brakes while simultaneously rotating the wheel backwards. This may result in ejection of the brake pad resulting in serious harm, accident, bodily injury or death. These pads are designed only for use with Enve carbon road rims and should never be used with aluminum rims.
Ordering
These pads are sold in pairs for one brake caliper. Please note that pads are included with new Enve rims and wheels. Campagnolo style pad holders are compatible with current Campagnolo brakes as well as those manufactured in 2000-2010.
Comment on Enve Carbon Brake Pads
