ENVE 65 Carbon Clincher Rim
Weight 485 grams
Width 21.5 mm
Depth 65 mm
Available Drillings 16, 20, 24, 28 hole
Tire Compatibility Clincher, 700c
ERD 527 mm
ENVE 65 Carbon Clincher Rim 16 Hole $875.00 In Stock
ENVE 65 Carbon Clincher Rim 20 Hole $875.00 Notify Me When Available
ENVE 65 Carbon Clincher Rim 24 Hole $875.00 In Stock
ENVE 65 Carbon Clincher Rim 28 Hole $875.00 In Stock
ENVE 65 Carbon Clincher Rim Stealth Black Decal $3.50 In Stock
ENVE 65 Carbon Clincher Rim Blue Outline Decal $3.50 In Stock
ENVE 65 Carbon Clincher Rim Blue Outline, White Logo Decal $3.50 In Stock
ENVE 65 Carbon Clincher Rim Gold Outline Decal $4.50 In Stock
ENVE 65 Carbon Clincher Rim Metallic Red Outline $3.50 In Stock
ENVE 65 Carbon Clincher Rim Red Outline $3.50 In Stock
ENVE 65 Carbon Clincher Rim Red Outline Decal $3.50 In Stock
ENVE 65 Carbon Clincher Rim Red Outline, White Logo Decal $3.50 In Stock
ENVE 65 Carbon Clincher Rim White Outline Decal $3.50  8 Remaining
Details
The Enve 65 clincher rim may be ideally applied to several cycling disciplines. Perhaps the most obvious application, owing to this rim's deep cross section, is in races against the clock. A deeper rim is nearly by default more aerodynamic; airflow is smoothed over a larger area and less spoke length is exposed to the wind. Additionally, at 65 mm, the depth is more modest than other manufacturers' offerings, avoiding complications that can arise in strong crosswinds. This large cross section also helps to create a wheel that possesses greater overall stiffness, an excellent trait in the constant accelerations and aggressive cornering encountered in criterium or cyclocross racing. To top it all off, the 65 is no heavyweight and would certainly not preclude the possibility of riding fast uphill.
Each 65 clincher rim includes an Enve rim strip, a 55 mm valve extender, the required Pillar internal spoke nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
To order your custom decal set, simply purchase a decal upgrade for each rim purchased. Decals are not available separate from rim purchases. Rims are shipped with decals applied. Standard rims include the stock Enve decal: silver outline, white logo.
Assembly
Comment on ENVE 65 Carbon Clincher Rim
