ENVE 45mm Tubular Specifications
Specifications | Weight | 295 grams |
| Width | 21.5 mm |
| Depth | 45 mm |
| Available Drillings | 20, 24 hole |
| Tire Compatibility | tubular, 28" |
| ERD | 564 mm |
ENVE 45mm Tubular Detail
Enve Composites' 1.45 carbon tubular is a lightweight, wind tunnel proven, and race ready rim. A wheelset built with the reasonably deep section 1.45 rims is suitable for almost any riding condition, whether the road goes up or down, whether the wind tosses you around or flies with you at your back. For the independently self-supported racer or discerning cyclist, the 1.45 is an excellent choice for a multi-purpose wheelset.
Each 1.45 rim includes an Enve 39 mm valve extender, Pillar internal spoke nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
Wheel Building
ENVE 45 Semi-Custom Decals
We're happy to provide you with a selection of custom ENVE Decals exlusively through Fairwheel Bikes. The decals can be ordered separately, with a rim or as a free upgrade with a hand built wheel set. Each set comes with six decals, enough for one wheel.
ENVE 45 Wheel Gallery
We've selected a few wheel builds we've done including examples of a few of the decals available.
- Red Outline, White Decals
- Metalic Red Outline
- Black Outline Decals
- Gold Outline Decals
