ENVE 45 Carbon Clincher Rim
45mm Rim Specifications
Weight 445 grams
Width 21.5 mm
Depth 45 mm
Available Drillings 20, 24 hole
Tire Compatibility tubular, 28"
ERD 564 mm
ENVE 45 Carbon Clincher Rim 18 Hole $875.00 Notify Me When Available
ENVE 45 Carbon Clincher Rim 20 Hole $875.00 In Stock
ENVE 45 Carbon Clincher Rim 24 Hole $875.00 In Stock
ENVE 45 Carbon Clincher Rim 28 Hole $875.00 In Stock
ENVE 45 Carbon Clincher Rim Silver Outline, White Logo Decal $3.50 In Stock
ENVE 45 Carbon Clincher Rim Black Outline Decal $6.50 Notify Me When Available
ENVE 45 Carbon Clincher Rim Blue Outline Decals $6.50 In Stock
ENVE 45 Carbon Clincher Rim Blue Outline, White Logo Decal $6.50 Notify Me When Available
ENVE 45 Carbon Clincher Rim Gold Outline Decal $6.50 In Stock
ENVE 45 Carbon Clincher Rim Metallic Red Outline Decal $6.50 In Stock
ENVE 45 Carbon Clincher Rim Red Outline Decal $6.50 In Stock
ENVE 45 Carbon Clincher Rim Red Outline, White Logo Decal $6.50 In Stock
ENVE 45 Carbon Clincher Rim White Outline Decal $6.50 In Stock
ENVE 45 Carbon Clincher Rim Yellow Outline Decal $6.50 In Stock
ENVE 45mm Clincher Detail
ENVE Composites' 1.45 carbon tubular is a lightweight, wind tunnel proven, and race ready rim. A wheelset built with the reasonably deep section 1.45 rims is suitable for almost any riding condition, whether the road goes up or down, whether the wind tosses you around or flies with you at your back. For the independently self-supported racer or discerning cyclist, the 1.45 is an excellent choice for a multi-purpose wheelset.
Each 1.45 rim includes an Enve 39 mm valve extender, Pillar internal spoke nipples , and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
For a limited time - decal upgrades are complimentary on custom wheelsets .
Wheel Building
We recommend that wheels built with Enve rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly or submit a custom wheel build request here .
ENVE 45 Semi-Custom Decals
We're happy to provide you with a selection of custom ENVE Decals exlusively through Fairwheel Bikes. The decals can be ordered separately, with a rim or as a free upgrade with a hand built wheel set. Each set comes with six decals, enough for one wheel.
ENVE 45 Wheel Gallery
We've selected a few wheel builds we've done including examples of a few of the decals available.
Comment on ENVE 45 Carbon Clincher Rim
