| Weight | 350 grams |
| Width | 24 mm |
| Depth | 32 mm |
| Available Drillings | 28, 32 hole |
| Tire Compatibility | 26" clincher (ISO 559), 26" UST |
| ERD | 533 |
About Enve Composites
Enve's UST series represents the next evolution of their line of mountain rims. In modifying the rim bead and tire channel to conform with the industry leading tubeless standard developed by Mavic, Enve has pushed their product into the forefront of cycling technology. Now a product that was both lightweight and incredibly stiff and responsive also allows for the use of tubeless tires which decrease rolling resistance, increase traction, and allow for a lower range of tire pressures without the risk of pinch flatting. And best of all, this new design features no weight penalty over the previous non-tubeless design.
Enve XC rims are strong, building into a much stiffer wheel than standard cross country aluminum rims. Durability is also an asset, with a special sidewall laminate and wide 24 millimeter rim width, further increasing strength. Enve says that aluminum counterparts "pale in comparison", and we couldn't agree more. These rims build in to some of the stiffest, lightest, and strongest wheels we've assembled.
Included with each Enve XC rim is a sealed tubeless valve and a roll of tubeless rim tape. As with most tubeless rims, Enve's XC UST rims are also compatible with standard tube and tire setups.
Assembly
We recommend that wheels built with Enve rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact
us directly or submit a custom wheel build request here.
