Specifications| Weight | 235 grams |
| Width | 24 mm |
| Depth | 32 mm |
| Available Drillings | 24, 28, 32 hole |
| Tire Compatibility | 26 tubular |
| ERD | 533 |
About Enve Composites
Whether you're looking to gain every last advantage in cross country racing, or desperately seeking to shed that last bit of excess weight off your already insanely light mountain rig, this 26 tubular rim from Enve Composites is calling.
At Fair Wheel Bikes, we'll be the first to admit that mountain tubulars aren't for everyone. The expense and hassle of obtaining and gluing tires would have most riders aching to just get out and ride. However, the benefits of running a tubular tire in the dirt are definitely worth considering. Beyond the most obvious weight advantage (this rim is over 100 grams lighter than Enve's clincher version), there are performance benefits as well. Compared to clinchers, lower tire pressures can be used to increase traction and cornering performance while eliminating the possibility of pinch flats.
Assembly
