ENVE 45 Carbon Tubular Rim
Sign Up For Our Newsletter
You're Signed Up!
Weight 302 grams
Width 21.5 mm
Depth 45 mm
Available Drillings 20, 24 hole
Tire Compatibility tubular, 28"
ERD 564 mm
Product Manuals
Enve Valve Extender Installation Video
Full Enve Owners Manual
ENVE 45 Carbon Tubular Rim 20 Hole $780.00  1 Remaining
ENVE 45 Carbon Tubular Rim 24 Hole $780.00  1 Remaining
ENVE 45 Carbon Tubular Rim 28 Hole $780.00 Notify Me When Available
ENVE 45 Carbon Tubular Rim Silver Outline, White Logo Decal $3.50 In Stock
ENVE 45 Carbon Tubular Rim Black Outline Decal $6.50  24 Remaining
ENVE 45 Carbon Tubular Rim Blue Outline Decals $6.50 In Stock
ENVE 45 Carbon Tubular Rim Gold Outline Decal $6.50 In Stock
ENVE 45 Carbon Tubular Rim Metallic Red Outline Decal $6.50 In Stock
ENVE 45 Carbon Tubular Rim Red Outline Decal $6.50 In Stock
ENVE 45 Carbon Tubular Rim Red Outline, White Logo Decal $6.50 In Stock
ENVE 45 Carbon Tubular Rim White Outline, Fuschia Logo Decal $6.50 In Stock
ENVE 45 Carbon Tubular Rim Yellow Outline Decal $6.50 In Stock
ENVE 45mm Tubular Detail
ENVE Composites' 1.45 carbon tubular is a lightweight, wind tunnel proven, and race ready rim. A wheelset built with the reasonably deep section 1.45 rims is suitable for almost any riding condition, whether the road goes up or down, whether the wind tosses you around or flies with you at your back. For the independently self-supported racer or discerning cyclist, the 1.45 is an excellent choice for a multi-purpose wheelset.
Each 1.45 rim includes an Enve 39 mm valve extender, internal brass nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
Shipping ENVE Internationally
Wheel Building
ENVE 45 Wheel Gallery
We've selected a few wheel builds we've done including examples of a few of the decals available.
Comment on ENVE 45 Carbon Tubular Rim
