Drawing upon their over 25 years experience in the composites industry and their passion for cycling, the folks at Edge Composites have created an innovative new product line with their 1.0 series tubular carbon rims.
Using a proprietary molding process in which the spoke holes are molded and not drilled, Edge has created a spoke interface that permits the running of higher spoke tensions without compromising the integrity of the rim. And not only does the spoke interface allow for higher tension, it is designed to enhance the durability of the wheel as a whole by limiting spoke fatigue. The result is a low maintenance, long lasting, and highly durable wheel. Other features of Edge's unique molding process include an elevated brake surface for optimized braking performance and longer rim life, and impact resistant sidewall construction for overall durability.
This 1.38 tubular rim has a 38mm deep aerodynamic section with 20 molded spoke holes.
Edge Composites recommends Swiss Stop's yellow "King" compound brake pads for use on their rims.
Weight: 272g
