A Cycling Boutique
Edge Handlebar; Mountain RiserEdge describes their "Mountain Riser" as "our all-everything bar". And they do so for two reasons: it's reasonably light, within a few grams of the lightest Easton and Bontrager cross country bars, and quite strong. We measured the wall thickness of several of our high-end carbon bars, and the Edge lead the group, with .2 to .3mm thicker walls. It's a visually perceivable difference, as well as a difference that should give larger, aggressive riders confidence in the strength of the bar. The bar measures 27.5-inches wide and are marked for cutting if you'd like to take them down in width.
165g
