Edge Carbon Seatpost, Zero Offset
Detail With their clean lines and simple design, these zero setback seatposts are a perfect example of the Edge design sensibility. The one-piece construction is performed by wrapping sheets of carbon prepreg sheets around a mandrel, resulting in a higher strength to weight ratio than is available in pultruded tubes. Because of this high strength construction, the Edge carbon seat post is at home both on the road or on the trail. The rail clamp sits cleanly in a round socket, and uses a simple 1-bolt wedge to hold everything together. Unidirectional carbon with an eggshell sheen provides an elegant finish with bold printed logos. Each Edge seatpost includes two saddle rail adapter clamp sets: one for 7 mm round rails and another for 7 x 9 mm oval carbon rails.
