| Weight | 450 grams |
| Width | 21.5 mm |
| Depth | 45 mm |
| Available Drillings | 18, 20, 24, 28 hole |
| Tire Compatibility | clincher, 700c (ISO 622) |
| ERD | 564 mm |
About Enve Composites
In the creation of the 45 Clincher, Enve has combined their over 25 years of experience in the composites industry to create a better product. This rim combines wind tunnel tested aerodynamics and a reasonably light weight with the convenience of a clincher. A wheelset built with 45 clincher rims is suitable for almost any riding condition, whether the road goes up or down, whether the wind tosses you around or flies with you at your back. These rims can be ridden every day or reserved for the year's most important events.
Each 45 clincher rim includes an Enve rim strip, a 39 mm valve extender, the required Pillar internal spoke nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
Assembly
