ENVE 65 Carbon Tubular Rim
Sign Up For Our Newsletter
You're Signed Up!
Weight408 grams
Width21.5 mm
Depth65 mm
Available Drillings16, 20, 24, 28 hole
Tire Compatibilitytubular, 28"
ERD527 mm
Product Manuals
Enve Valve Extender Installation Video
Full Enve Owners Manual
ENVE 65 Carbon Tubular Rim 16 Hole $780.00 Notify Me When Available
ENVE 65 Carbon Tubular Rim 20 Hole $780.00 In Stock
ENVE 65 Carbon Tubular Rim 24 Hole $780.00 In Stock
ENVE 65 Carbon Tubular Rim 28 Hole $780.00 Notify Me When Available
ENVE 65 Carbon Tubular Rim Stealth Black Decal $3.50  20 Remaining
ENVE 65 Carbon Tubular Rim Blue Outline Decal $3.50 In Stock
ENVE 65 Carbon Tubular Rim Blue Outline, White Logo Decal $3.50 In Stock
ENVE 65 Carbon Tubular Rim Gold Outline Decal $4.50 In Stock
ENVE 65 Carbon Tubular Rim Metallic Red Outline $3.50 In Stock
ENVE 65 Carbon Tubular Rim Red Outline, White Logo Decal $3.50 In Stock
ENVE 65 Carbon Tubular Rim Silver Outline White Logo Decal $3.50 In Stock
ENVE 65 Carbon Tubular Rim White Outline Decal $3.50 In Stock
About Enve Composites
Details
The Enve 1.65 tubular rim may be ideally applied to several cycling disciplines. Perhaps the most obvious application, owing to this rim's deep cross section, is in races against the clock. A deeper rim is nearly by default more aerodynamic; airflow is smoothed over a larger area and less spoke length is exposed to the wind. Additionally, at 65 mm, the depth is more modest than other manufacturers' offerings, avoiding complications that can arise in strong crosswinds. This large cross section also helps to create a wheel that possesses greater overall stiffness, an excellent trait in the constant accellerations and aggressive cornering encountered in criterium or cyclocross racing. To top it all off, the 1.65 is no heavyweight and would certainly not preclude the possibility of riding fast uphill.
Each 1.65 rim includes an Enve 55 mm valve extender, Enve brass internal nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
Assembly
