| Weight | 360 grams |
| Width | 21.5 mm |
| Depth | 65 mm |
| Available Drillings | 16, 20, 24, 28 hole |
| Tire Compatibility | tubular, 28" |
| ERD | 527 mm |
About Enve Composites
The Enve 1.65 tubular rim may be ideally applied to several cycling disciplines. Perhaps the most obvious application, owing to this rim's deep cross section, is in races against the clock. A deeper rim is nearly by default more aerodynamic; airflow is smoothed over a larger area and less spoke length is exposed to the wind. Additionally, at 65 mm, the depth is more modest than other manufacturers' offerings, avoiding complications that can arise in strong crosswinds. This large cross section also helps to create a wheel that possesses greater overall stiffness, an excellent trait in the constant accellerations and aggressive cornering encountered in criterium or cyclocross racing. To top it all off, the 1.65 is no heavyweight and would certainly not preclude the possibility of riding fast uphill.
Each 1.65 rim includes an Enve 55 mm valve extender, the required Pillar internal spoke nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
Assembly
