Specifications| Weight | 485 grams |
| Width | 21.5 mm |
| Depth | 65 mm |
| Available Drillings | 16, 20, 24, 28 hole |
| Tire Compatibility | Clincher, 700c |
| ERD | 527 mm |
About Enve Composites
The Enve 65 clincher rim may be ideally applied to several cycling disciplines. Perhaps the most obvious application, owing to this rim's deep cross section, is in races against the clock. A deeper rim is nearly by default more aerodynamic; airflow is smoothed over a larger area and less spoke length is exposed to the wind. Additionally, at 65 mm, the depth is more modest than other manufacturers' offerings, avoiding complications that can arise in strong crosswinds. This large cross section also helps to create a wheel that possesses greater overall stiffness, an excellent trait in the constant accelerations and aggressive
cornering encountered in criterium or cyclocross racing. To top it all off, the 65 is no heavyweight and would certainly not preclude the possibility of riding fast uphill.
Each 65 clincher rim includes an Enve rim strip, a 55 mm valve extender, the required Pillar internal spoke nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
For a limited time - decal upgrades are complimentary on custom
wheelsets.
Assembly
We recommend that wheels built with Enve rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions
in hub and spoke selections. Please contact us directly or submit a custom wheel build request here.
