Enve 1.45 Carbon Tubular Rim
Enve 1.45 Carbon Tubular Rim 20 Hole$780.00  1 Remaining
Enve 1.45 Carbon Tubular Rim 24 Hole$780.00  1 Remaining
Enve 1.45 Carbon Tubular Rim 28 Hole$780.00  2 Remaining
Enve 1.45 Carbon Tubular Rim Decal Upgrade Blue Outline$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade Blue Outline, White Logo$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade Gold Outline$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade Metallic Red Outline$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade Red Outline$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade Red Outline, White Logo$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade Stealth Black$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade White Outline$30.00 In Stock
Enve 1.45 Carbon Tubular Rim Decal Upgrade, Yellow Outline$30.00 In Stock
Weight295 grams
Width21.5 mm
Depth45 mm
Available Drillings20, 24 hole
Tire Compatibilitytubular, 28"
ERD564 mm
About Enve Composites
Enve Composites' 1.45 carbon tubular is a lightweight, wind tunnel proven, and race ready rim. A wheelset built with the reasonably deep section 1.45 rims is suitable for almost any riding condition, whether the road goes up or down, whether the wind tosses you around or flies with you at your back. For the independently self-supported racer or discerning cyclist, the 1.45 is an excellent choice for a multi-purpose wheelset.
Each 1.45 rim includes an Enve 39 mm valve extender, Pillar internal spoke nipples, and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required.
Ordering
Assembly
Comment on Enve 1.45 Carbon Tubular Rim
