Edge 1.38 Carbon Tubular Wheels, 24h, Campy
$2,250.00 Free Shipping!!!
*on all continental US orders
  • 24 hole
  • 1040 grams (without skewers)
  • Campagnolo compatable
Simply put, these wheels represent an optimal combination of the three attributes a race quality wheel strives to be: light-weight, strength, and aero-dynamics. The expert wheel builders at Fairwheel Bikes have brought together the very best parts available to create a superb set of wheels utilizing Edge 1.38 carbon tubular rims, Extralite SL/SR hubs, and DT Swiss aerolight spokes.
This translates in to a wheelset without compromise. For starters, the Edge 1.38 rims are extremely light at 272 grams, while maintaining an aero profile of 38mm. However, strength, stiffness, and durability are not lost on them. We've laced 24 of DT Swiss's Aerolight spokes to the Edge rim.
Edge utilizes a proprietary method in the fabrication process, where the spokes are molded and not drilled. This allows a higher spoke tensioned to be wound than possible on competing carbon rims. Consequently, the end wheelset is strong and dependable, while increasing spoke fatigue life, and braking performance.
We haven't come across hubs much lighter than the Extralite's, that don't sacrifice a critical performance attribute. When hubs get much lighter, they generally utilize micro-bearings, which have a higher drag and lower life. Extralite uses and oversized axle, an extra hardening process for radial lacing, and they're strong enough for cross-country use, all while weighing in at just 162 (SR) /62 grams (SL) rear/front respectively.
Weight: 1040g
For more information on the components used, please click on the links below:
Edge 1.38 Carbon Tubular Rims
Extralite Hubs
DT Swiss Aerolight Spokes
Add to Cart:
  • Model: EDG28576010Y
  • Manufactured by: Edge Composites
Copyrighted © by Fairwheel Bikes   All Rights Reserved.
Zen Cart customization by Pushing Buttons Az
Minor Theme Customization by Potent Products
