Enve 1.25 Carbon Tubular Rim
Enve 1.25 Carbon Tubular Rim 20 Hole$780.00  1 Remaining
Enve 1.25 Carbon Tubular Rim 24 Hole$780.00  2 Remaining
Enve 1.25 Carbon Tubular Rim 28 Hole$780.00  2 Remaining
Enve 1.25 Carbon Tubular Rim Decal Upgrade Blue Outline$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade Blue Outline, White Logo$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade Gold Outline$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade Metallic Red Outline$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade Red Outline$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade Red Outline, White Logo$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade Stealth Black$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade White Outline$20.00 In Stock
Enve 1.25 Carbon Tubular Rim Decal Upgrade, Yellow Outline$20.00 In Stock
Weight260 grams
Width21 mm
Depth25 mm
Available Drillings20, 24, 28 hole
Tire Compatibilitytubular, 28"
ERD607 mm
About Enve Composites
Combining over 25 years experience in the composites industry and their passion for cycling, Enve Composites has created an innovative product in their 1.25 carbon tubular rim. This rim combines a respectable light weight with durability and strength that few manufacturers can match, even with rim cross sections twice as deep.
Each Enve 1.25 rim includes the required Pillar internal spoke nipples and a pair of Enve's proprietary brake pads - please indicate upon purchase whether Shimano or Campagnolo style pads are required
Ordering
Assembly
