DT Swiss Hub Small Parts
Sign Up For Our Newsletter
You're Signed Up!
DT Swiss Hub Small Parts 36 Tooth SL Ratchet System $96.72 Notify Me When Available
DT Swiss Hub Small Parts Front 100 mm QR, 240 Oversized $46.80 In Stock
DT Swiss Hub Small Parts Front 100 mm QR, 240s / Tricon $40.50 Notify Me When Available
DT Swiss Hub Small Parts Front 15mm Thru Axle Adapter, 240 Oversized $46.80 Notify Me When Available
DT Swiss Hub Small Parts Front 15mm Thru Axle Adapter, 240s Fifteen / Tricon $37.80 Notify Me When Available
DT Swiss Hub Small Parts Rear 135 mm QR for 190/240/440 $45.00 In Stock
DT Swiss Hub Small Parts Rear 240s 142 mm x 12mm Thru Axle and Adapters $58.50  1 Remaining
DT Swiss Hub Small Parts Six Bolt Adapter $18.90 In Stock
DT-Swiss hubs are extremely flexible due to their modular engineering. Converting mountain bike hubs for for axle compatibility, bearing quality and even fine tuning engagement is easily done with minimal time and effort. If you're looking to convert your rear DT-Swiss hub between SRAM XX1, Shimano and Campagnolo check our Freehub Conversion Kits.
The 36 tooth SL ratchet system is a replacement and upgrade for DT-Swiss hubs. The tooth count is twice as much as the standard ratchet system shipped in DT-Swiss road and mountain bike hubs. This decreases the engagement angle from 20 degrees to just 10. The SL ratchet kit is also manufactured using less material saving an extra 10 grams over the ratchet system that ships with 240 and 350 hubs. All ratchet systems are made from the same high grade steel.
Comment on DT Swiss Hub Small Parts
