DT Swiss 350 Road Hub
Sign Up For Our Newsletter
You're Signed Up!
Weight, Straight Pull108 grams
264 grams
Weight, J-Bend149 grams,252 grams
Bearing Sizes6902 (2), 6802 (2)
Axle Diameter15 mm
Available Hole Count24, 28 hole
Recommended UseRoad
Wheelbuilding Dimensions
Straight Pull Rear*
Left Flange Diameter38.5 mm
Right Flange Diameter45.5 mm
Center to Left Flange33.3 mm
Center to Right Flange15.8 mm
*Use only straight pull spokes, laced 3x
Straight Pull Front*
Flange Diameter26.2 mm
Center to Left37.0 mm
J-Bend Rear
Left Flange Diameter45 mm
Right Flange Diameter45mm
Center to Left Flange32.6 mm
Center to Right Flange16.9 mm
J-Bend Front
Flange Diameter38.8 mm
Flange to Center37.3
DT Swiss 350 Road Hub Front, 28 Hole $65.00 In Stock
DT Swiss 350 Road Hub Rear, 28 Hole, Shimano $219.00 In Stock
DT Swiss 350 Road Hub Straight Pull, Front, 24 Hole $80.00  1 Remaining
DT Swiss 350 Road Hub Straight Pull, Rear, 28 Hole $275.00 In Stock
Hub Details
DT Swiss presents to the cycling world an intriguing line of hubs with their 350 series. Aimed at bringing DT’s legendary craftsmanship and quality down a notch in price, the 350 is an excellent choice for budget-minded cyclists who nonetheless desire a high quality, hand-built wheelset. In order to keep prices low, DT Swiss has simplified their manufacturing by making these hubs available in limited spoke counts; these straight pull versions are only available in 24 front, 28 rear counts. While that may limit rim options somewhat, a 24/28 spoke wheelset will provide excellent durability and long life for a wide range of rider weights and riding conditions.
350 rear hubs are equipped with DT’s star ratchet freehub mechanism. This simple, yet extremely durable system has proved itself with well over a decade of use within the industry. The star ratchet system is 100% user-serviceable, requiring no special tools for cleaning and re-lubrication. Also, the freehubs are easily interchanged between Campagnolo and Shimano, with 100% compatibility between either manufacturers’ 10 and 11 speed cassettes.
The highly regarded reputation and expansive proliferation of DT Swiss hubs within the cycling market makes the purchase of a DT hub set a very safe investment indeed. The hubs are easily serviced and use common bearing sizes, so the likelihood of your local shop possessing the necessary tools and knowledge for proper overhaul are quite high. Also, the failure rate among DT hubs are perhaps the lowest in the industry, and all hubs are covered under a 2-year warranty against defects in materials and production.
Comment on DT Swiss 350 Road Hub
