DT Swiss 240s Straight Pull Rear Road Hub
Sign Up For Our Newsletter
You're Signed Up!
Weight212 grams
Bearing Size6902 (2), 6802 (2)
Recommended UseRoad
CompatibilityShimano/Sram 9/10, Shimano 11, Campagnolo 9/10/11 (with proper freehub body)
Wheelbuilding Dimensions*
Left Flange Diameter38.5 mm
Right Flange Diameter45.5 mm
Center to Left Flange33.3 mm
Center to Right Flange15.8 mm
*Use only straight pull spokes, laced 3x
DT Swiss 240s Straight Pull Rear Road Hub 24 Hole $405.00 Notify Me When Available
Details
The bike mechanic's yardstick for measuring the durability and serviceability of all hubs has long been the 240s by DT Swiss. Practically indestructible and incredibly smooth, the 240s certainly deserves such a title. Now available in a straight pull option for those looking to save a few grams and obtain a slight increase in aerodynamics. The DT Swiss 240s Straight Pull will quickly prove to be one of the best investments you can make for your bike.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
