DT Swiss 240s Road Rear Hub
DT Swiss 240s Road Rear Hub 24 Hole, Campagnolo$415.00  1 Remaining
DT Swiss 240s Road Rear Hub 24 Hole, Shimano$415.00  1 Remaining
DT Swiss 240s Road Rear Hub 28 Hole, Campagnolo$415.00  1 Remaining
DT Swiss 240s Road Rear Hub 28 Hole, Shimano$415.00  1 Remaining
DT Swiss 240s Road Rear Hub 32 Hole, Campagnolo$415.00  1 Remaining
DT Swiss 240s Road Rear Hub 32 Hole, Shimano$415.00  1 Remaining
Weight, Shimano220 grams
Weight, Campagnolo210 grams
Bearing Sizes6902 (2), 6802 (2)
Axle Diameter15 mm
Available Drillings24, 28, 32 hole
Hub Shell Materialaluminum
Drive Ring Materialsteel
Wheel Building Dimensions
Left Flange Diameter45 mm
Right Flange Diameter45 mm
Center to Left Flange32.6 mm
Center to Right Flange16.9 mm
DT's venerable 240s hubs have achieved a near-legendary status with a decade of production and heavy use by many of the industry's top wheel manufacturers, including Enve, Reynolds, and Bontrager. The 240s has defined itself as a mechanics' favorite; an extremely durable and dependable hub, with a lightweight, easily serviceable design.
DT's 240s rear hubs feature their precision star ratchet engagement system, which is both strong, quiet (when properly lubricated), and user-serviceable. This system differs dramatically from the common spring-and-pawl designs, which have many small parts that are susceptible to premature wear or breakage.
Manufactured in Switzerland
Assembly
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Links
DT Swiss Freehub Conversion Kits
Comment on DT Swiss 240s Road Rear Hub
