DT Swiss 240s Rear Disc Hub
Sign Up For Our Newsletter
You're Signed Up!
Bearing Sizes6902 (2), 6802 (2)
Hub Shell Materialaluminum
Drive Ring Materialsteel
Wheel Building Dimensions, Centerlock
Flange Diameter, Left44 mm
Flange Diameter, Right47.5 mm
Center to Left Flange32.4 mm
Center to Right Flange19.4 mm
Weight221 grams
Wheel Building Dimensions, 6 bolt
Flange Diameter, Left57 mm
Flange Diamter, Right47.5 mm
Center to Left Flange34 mm
Weight233 grams/td>
DT Swiss 240s Rear Disc Hub 32 Hole, 6 bolt, QR $430.00 Notify Me When Available
DT Swiss 240s Rear Disc Hub 32 hole, Centerlock, QR $430.00 Notify Me When Available
Details
With over a decade of use and abuse as a nearly indestructible road hub, the 240 by DT Swiss is arguably one of the finest hubs to date. With legendary quality and craftsmanship behind each hub, it’s easy to see why the 240 is a favorite among many mechanics and cyclists. By bringing that same quality to hand built mountain bike wheelsets, DT Swiss has potentially created the most durable hub option to date. By utilizing their precision star ratchet freehub body system, the DT 240s is a user serviceable hub with few moving parts, guaranteeing longevity and simplicity of service. No special tools are required to clean and regrease the 240s freehub body, making it the mechanic’s favorite in nearly every shop.
With a market wide acceptance that the DT 240s is one of the best options for your wheelset, it’s easy to see that DT Swiss products are a sound investment. With their bomb proof freehub body system coupled with the use of very common bearing sizes, the DT 240s can be completely overhauled by almost any bike shop.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Manufactured in Switzerland
Comment on DT Swiss 240s Rear Disc Hub
