DT Swiss 240s Front Disc Hub
Sign Up For Our Newsletter
You're Signed Up!
Specification
Bearing Size6803 (2)
Hub Shell Materialaluminum
Wheel Building Dimensions, 6 bolt
Flange Diameter, Left58 mm
Flange Diameter, Right42 mm
Center to Left Flange22 mm
Center to Right Flange42 mm
Weight145 grams
Wheel Building Dimensions, Centerlock Fifteen
Flange Diameter, Left44 mm
Center to Left Flange22.5 mm
Center to Right Flange35.6 mm
Weight126 grams
DT Swiss 240s Front Disc Hub 32 hole, 6 bolt $222.00 Notify Me When Available
DT Swiss 240s Front Disc Hub 32 hole, Centerlock, 15 mm $233.00 Notify Me When Available
Details
Known for producing some the world’s finest hubs, DT Swiss is a household name in every bike shop. Hailed for their unsurpassable durability and modular design, the road DT 240s has long been the flagship for the DT Swiss product line, and for good reason. Not to leave the MTB crowd in the dust, DT now offers a hub with the same credentials and ingenious design for those looking for a hand built mountain wheelset. Expertly crafted to be easily serviceable, and utilizing common bearing sizes that are available in any modern bike shop, the front DT 240s is the ideal companion for the rear mountain DT 240s. With possibly the lowest failure rate of any hub on the market, any DT hub is a sound investment that should last through miles of use and abuse.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Made is Switzerland
