DT Swiss 180 Front Road Hub
Sign Up For Our Newsletter
You're Signed Up!
Weight 98 grams
Bearings 6803 (2)
Available Drillings 20 hole
Hub Shell Material Aluminum
Carbon Sleeve
Wheel Building Dimensions
Flange Diameter 38.8 mm
Flange to Center 37.3 mm
DT Swiss 180 Front Road Hub 20 Hole $424.97  1 Remaining
Details
DT’s 180 front hub has been tuned and weight optimized to create an extraordinarily durable, high performance, lightweight hub. The hub can be laced in cross and radial patterns thanks to the sturdy 7000 series aluminum flanges. A UD carbon hub shell shaves weight without compromising strength while the high performance ceramic bearings rest on a 17mm alloy axle. The hub is completely serviceable without tools for the hassle-free maintenance you’d expect from DT products.
