Derailleur Parts
Extralite's rear derailleur pulleys are Shimano and Campagnolo compatible. An excellent after-market replacement component, Extralite's pulleys are a...
$58.000 in stock.View
Specifications CompatibilityCampagnolo RoadColorsBlack, Gold, Red Contents Front Derailleur m5 x 15mounting bolt and washerm3 x 18limit screws (2)m5...
$85.005 options.View
Specifications CompatibilityShimano RoadColorsBlack, Gold, Red Contents Front Derailleur m5 x 13mounting bolt and washerm4 x 11limit screws (2)m5 x...
$100.003 options.View
Specifications CompatibilitySRAM RoadColorsBlack, Gold, Red Contents Front Derailleur m5 x 16mounting bolt and washerm3 x 18limit screws (2)m5 x...
Specifications Weight2.7 gramsMaterial7075 aluminumThreadM5 x 11 Detail Alligator's stylish aluminum barrel adjusters are designed to fit any...
$8.005 options.View
Specifications Weight w/ Bolt and Spacer 5.6 grams Compatibility braze-on derailleur tabs only Material 7075 aluminum Detail A...
$28.004 options.View
Specifications Weight 2.0 grams per pair Compatibility 11 speed Super Record, Record, and Chorus Available Colors black, blue, gold, green,...
$10.006 options.View
Far and Near Pulley Wheel DetailWeight11 grams per pulleyMaterial7075 aluminumBearing Size689Pulley Size11 toothDerailleur CompatibilityShimano,...
$40.004 options.View
Far and Near Pulley Wheel DetailWeight11 grams per pulleyMaterial7075 aluminumBearing Size689Pulley Size11 toothDerailleur CompatibilityCampagnolo 11...
$40.006 options.View
A replacement gear mech. plate, made from 2.3mm carbon fiber, with aluminum inserts for threads (where threads are required). Available for XTR...
$32.0013 options.View
Fibre-Lyte's lightweight pulley wheels are precision-machined from sheets of carbon fiber. All individual parts are easily disassembled for cleaning...
$90.002 options.View
Specifications Weight8.5 gramsMaterial7075 aluminumBearing Size689, hybrid ceramicAvailable Sizes10, 11, 12, 13 toothAvailable Colorsblack, blue,...
$35.0014 options.View
Specifications Weight 15 grams Material 6061 aluminum Available Sizes 28.6, 31.8, 34.9 mm Detail These front derailleur clamps, manufactured...
$15.0013 options.View
KCNC's new derailleur pulley bolt is yet another way to customize the look of your bike, while shedding a bit of weight. The replacement pulley bolts...
Specifications Weight (without bolt)8.2 gramsTooth Count11Pulley MaterialDLC coated 6/4titaniumBearing689, full ceramic Detail KCNC gets ridiculous...
$150.006 in stock.View
Specifications Weight, 10 tooth6.6 gramsWeight, 11 tooth6.9 gramsMaterial7075 aluminumBearing687 ,steelAvailable Sizes10, 11 tooth Detail Each KCNC...
$18.0012 options.View
Specifications Weight ~6 grams Material Carbon Fiber Body, Titanium screw Max Torque 6Nm Details Mcfk's carbon fiber front derailleur clamp is...
$80.001 options.View
Parlee Cycles created this front derailleur clamp for their own high-end carbon bicycle frames, and have made them available as an aftermarket...
Specifications Weight 21 grams/pair Bearing Size 606 Detail Soul Kozak's machined aluminum pulleys offer a simple, elegant option in aftermarket...
$20.000 in stock.View
The Third Eye Chain Watcher is one of many popular devices used to keep your chain from falling off your little chainring and in to your bike....
$11.000 in stock.View
