Road Cranksets
Extralite Ebones QRC-2 Crankset
Specifications Weight, Complete484 grams Bearing Size6806 (2) Bolt Circle Diameter110 mm (compact) Spindle Diameter27 mm Bottom Bracket OptionsBSA,...
$660.00
3 options.View
KCNC K-Type Road Crankset
Specifications Weight715 grams Available Lengths170, 172.5, 175 BCD130 Standard, 110 Compact Bottom Bracket68mm English, 70mm Italian Detail KCNC's...
$375.00
7 options.View
KCNC K2 Road Crankset
Specifications Weight 664grams Crank Arm Length 165, 170, 172.5, 175, 177.5, 180 mm Crank Arm Material 7075 aluminum Spindle Material...
$405.00  $303.75
Save: $101.25 off
2 options.View
Lightning Carbon Cranks
The long awaited crank from Lightning has finally seen the light of day. Often copied, replicated and licensed, Lightning's revolutionary crank is...
$670.00
6 options.View
THM Clavicula Compact Crankset
Specifications Weight 420 grams BB Compatibility 68 mm, English (1.37 x 24 tpi) Chainline 43.5 mm Available Lengths 170*, 172.5, 175* mm ...
$1,355.00
4 options.View
THM Clavicula M3 Carbon Crankset
Specifications Weight, crank arms only354 grams Weight, compact spider46 grams Weight, English BB Cups73 grams Spindle Diameter30 mm Bottom Bracket...
$1,085.00
12 options.View
THM Clavicula Road Crankset
$1,355.00
4 options.View
