Mountain Cranksets
Extralite Ebones W BB30 Crankset
Specifications Weight 498 grams Crank Length 172.5mm BCD 104 / 64 5 bolt Q Factor 160 mm Bearings 6806 Spindle...
$510.00
1 in stock.View
Extralite Ebones W Crankset
Specifications Weight 498 grams Crank Length 175 mm BCD 104 / 64 5 bolt Q Factor 160 mm Bearings 6806 Spindle...
$510.00
1 in stock.View
KCNC K-Type XC2 Double Crankset
KCNC's K-Type crankset / bottom bracket combo features a 3-piece design with an oversize scandium spindle and outboard bearings. This design is not...
$375.00
2 options.View
KCNC K-Type XC2 Triple Crankset
KCNC's K-Type crankset / bottom bracket combo features a 3-piece design with an oversized scandium spindle and outboard bearings. This design is not...
$375.00
3 options.View
KCNC K2 XC Triple Crankset
$405.00  $303.75
Save: $101.25 off
1 options.View
KCNC K2 XC2 Double Crankset
Specifications Weight 674 grams Crank Arm Length 170, 175 mm Crank Arm Material 7075 aluminum Spindle Material Scandium Available Colors...
$405.00  $303.75
Save: $101.25 off
4 options.View
Lightning Mountain Crankset
Specifications Weight, Crankset Only~400 gramsWeight, BSA Bottom Bracket95 gramsBearings6806 (2), ABEC 5 100% fillCrankarm Materialhollow carbon...
$670.00
2 options.View
THM Clavicula DP Mountain Crankset
Specifications Weight 415 grams BB Compatibility 68 or 73 mm English, +/- E-type Chainline 50 mm Available Lengths 170*, 172.5*, 175 mm Q...
$1,395.00
3 options.View
THM Clavicula DP68 Mountain Crankset
Specifications Weight 395 grams BB Compatibility 68 mm only, +/- E-type Chainline 47.5 mm Available Lengths 170*, 172.5*, 175 mm Q Factor...
$1,395.00
3 options.View
THM Clavicula Mountain Crankset
Specifications Weight 440 grams BB Compatibility 68 or 73 mm English, +/- E-type Chainline 50 mm Available Lengths 170*, 172.5*, 175 mm Q...
$1,260.00
3 options.View
Tune Smartfoot Mountain Crankset
Specifications Weight, without BB625 gramsMaterial7075 aluminumSpindle Diameter30 mmQ-Factor167 mmBCD104/64Chainrings44, 32, 22 toothAvailable Crank...
$700.00
3 options.View
