Chris King Single Speed Cog
Chris King Single Speed Cog 15 Tooth$42.00  1 Remaining
Chris King Single Speed Cog 16 Tooth$42.00  1 Remaining
Chris King Single Speed Cog 17 Tooth$42.00  2 Remaining
Chris King Single Speed Cog 18 Tooth$42.00  1 Remaining
Chris King Single Speed Cog 19 Tooth$42.00  2 Remaining
Chris King Single Speed Cog 20 Tooth$42.00  1 Remaining
Weight, 15 tooth 34 grams
Weight, 16 tooth 32 grams
Weight, 17 tooth 37 grams
Weight, 18 tooth 38 grams
Weight, 19 tooth 41 grams
Weight, 20 tooth 43 grams
Material stainless steel
Width
3/32"
These stainless steel cogs from Chris King Precision Components are the standard by which all other cogs are measured. These attactive drivetrain pieces are expertly machined in Portland, Oregon by one of the coolest companies on the planet. After machining, the cogs are heat treated and bead blasted for maximum durability and wear life.
Comment on Chris King Single Speed Cog
