Chris King R45 Rear Hub
Chris King R45 Rear Hub Black, 24 Hole$379.00  2 Remaining
Chris King R45 Rear Hub Black, 28 Hole$379.00  2 Remaining
Chris King R45 Rear Hub Gold, 24 Hole$379.00 Notify Me When Available
Chris King R45 Rear Hub Navy, 24 Hole$379.00  1 Remaining
Chris King R45 Rear Hub Pewter, 24 Hole$379.00  1 Remaining
Chris King R45 Rear Hub Pewter, 28 Hole$379.00 Notify Me When Available
Chris King R45 Rear Hub Pink, 24 Hole$379.00  1 Remaining
Chris King R45 Rear Hub Red, 24 Hole$379.00  2 Remaining
Chris King R45 Rear Hub Red, 28 Hole$379.00 Notify Me When Available
Chris King R45 Rear Hub Silver, 24 Hole$379.00  1 Remaining
Weight218 grams
Bearing Sizeproprietary stainless steel
Axle Diameter16.5 mm
Available Drillings24, 28, 32 hole
Available Colorsblack, brown, red, silver, gold,
navy, pewter, mango, green, pink
Useroad only
Wheel Building Dimensions
Left Flange Diameter51.0 mm
Right Flange Diameter51.0 mm
Left Flange to Center34.6 mm
Right Flange to Center18.9 mm
The R45 series is Chris King's response to market demand for a purpose-built road racing hubset. The R45's predecessor, the "Classic" series, was originally designed for mountain use, and merely adapted to standard road widths. Overbuilt bearing seals and the patently loud ratchet system that made these hubs so popular for mountain bikers hindered their success in the road market. Reengineering of that classic design has yielded a hub set with lower seal drag, quieter operation, and a 20% lower overall weight. The R45 hubs are also available in the lower spoke hole counts popular in modern road wheel sets. As with all of Chris King's products, these hubs feature immaculate finish work; the hub shells are highly polished prior to anodizing, which yields a deep, vibrant hue to each of the ten color options.
The R45 rear hub features a beefy 16.5 mm aluminum axle with a simple, on-the-go preload adjustment. Partial disassembly and service of three of the hub's four bearings is possible without specialized tools. To fully disassemble this hub, a Chris King Hub Service Tool Kit is required. At the heart of the R45 rear hub is Chris King's patented RingDrive. This clockwork-style ratchet system features 45 teeth for fast, secure, and quiet engagement.
R45 hubs are now available with Campagnolo-compatible freehub bodies.
Chris King products are manufactured with pride and confidence in Portland, Oregon, USA. R45 hubs are covered under a 5 year warranty against manufacturing and materials defects.
Assembly
Comment on Chris King R45 Rear Hub
