Chris King
Chris King Baseplate
Specifications Weight, Titanium 1-1/8"8 grams Weight, Stainless Steel 1-1/8"14 grams Weight, Stainless Steel 1-1/8" Tall28 grams Weight, Stainless...
$12.00
4 options.View
Chris King Bottom Bracket
Specifications Weight102 grams ThreadEnglish (BSA, 1.375" x 26 tpi) BearingKing Stainless Steel CompatibilityShimano HTII, Sram and Truvativ GXP,...
$135.00
9 options.View
Chris King Ceramic Road Bottom Bracket
Specifications Weight99 grams ThreadEnglish (BSA, 1.375" x 26 tpi) BearingKing Hybrid SS/Ceramic CompatibilityShimano HTII, Sram and Truvativ GXP,...
$199.00
2 options.View
Chris King InSet Headset
Specifications Weight90 grams Steerer Compatibility1 1/8" straight Stack Height12.7 mm Headtube Bore44.0 mm Description InSet is Chris King's entry...
$135.00
3 options.View
Chris King NoThreadSet 1.5"
The Chris King 1.5" NoThreadSet features the same legendary features if the 1 1/8" NoThreadSet, but in an over-sized package. The 1.5" NoThreadSet...
$170.00
0 in stock.View
Chris King NoThreadSet Headset 1-1/8"
Over 30 years ago, Chris King designed the first sealed bearing headset. Since then, King Precision Components has earned its current reputation for...
$135.00
15 options.View
Chris King R45 Campagnolo Rear Hub
Specifications Weight230 grams Bearing Sizeproprietary stainless steel Axle Diameter16.5 mm Available Drillings24, 28, 32 hole Available...
$369.00
2 options.View
Chris King R45 Ceramic Front Hub
Specifications Weight100 grams Bearing Sizeproprietary hybrid ceramic Axle Diameter17 mm Available Drillings20, 24, 28, 32 hole Available...
$229.00
2 options.View
Chris King R45 Ceramic Rear Hub
Specifications Weight217 grams Bearing Sizeproprietary hybrid ceramic Axle Diameter16.5 mm Available Drillings24, 28, 32 hole Available Colorsblack,...
$449.00
2 options.View
Chris King R45 Front Hub
Specifications Weight102 grams Bearing Sizeproprietary stainless steel Axle Diameter17 mm Available Drillings20, 24, 28, 32 hole Available...
$169.00
10 options.View
Chris King R45 Rear Hub
Specifications Weight218 grams Bearing Sizeproprietary stainless steel Axle Diameter16.5 mm Available Drillings24, 28, 32 hole Available...
$369.00
10 options.View
Chris King Single Speed Cog
Specifications Weight, 15 tooth 34 grams Weight, 16 tooth 32 grams Weight, 17 tooth 37 grams Weight, 18 tooth 38 grams Weight, 19 tooth 41...
$42.00
6 options.View
