Chris King InSet Headset
Chris King InSet Headset Black$139.00  1 Remaining
Chris King InSet Headset Red$139.00  1 Remaining
Chris King InSet Headset Silver$139.00  1 Remaining
Weight90 grams
Steerer Compatibility1 1/8" straight
Stack Height12.7 mm
Headtube Bore44.0 mm
Description
InSet is Chris King's entry into the contemporary bicycle market. It's not an intergrated headset; Mr. King said he would never make an intergrated headset, and he's still saying it. InSet, in the most general of terms, is the same heirloom quality King headset in a different shape. Call it what you will: semi-intergrated, zero stack, or internal, InSet is the same time tested King headset in a modern iteration. It's compatibility includes bicycles with headtube bores of 44.0mm. Select models from Giant, Jamis, Scott, Pivot, Santa Cruz, and Trek are compatible with this standard.
InSet uses King's in-house manufactured and user serviceable sealed bearings. The only major difference with InSet over the traditional NoThreadset is that the bearing resides inside rather than outside the headtube as a traditional external headset does. The superior quality sealed bearings still remain press fit in the headset cups, and in turn the headset cups are press fit inside the bicycle's headtube. The InSet features the same fucntionality as a traditional external King headset, only with a different shape.
Made in Portland Oregon and backed by a ten year warranty.
We highly recommend professional installation and frame prep from your favorite LBS.
Comment on Chris King InSet Headset
