Chainrings
Specifications Weight9 grams per set Material7075 T6 aluminum Recommended Torque5-6 Nm Detail Extralite's chainring bolts are precision machined...
$24.000 in stock.View
Specifications Weight 82g Size 28t/42t Colors Black/Ti anodized finish BCD 104mm Bolt Pattern 4 bolt pattern Shift Ramps CNC'ed Shift...
$174.001 in stock.View
Specifications Weight 107g/set Material Ergal 7075T6 Construction Hyper Accurate CNC Ramps 5 cnc with unique 15 degree profile Machined...
$175.000 in stock.View
Specifications Weight, 22t 16g Weight, 32t 33g Weight, 44t 61g Sizes 104x22/32/44 Material Ergal 7075T6 Construction Hyper Accurate CNC ...
$28.004 options.View
Specifications Weight94 grams per set Tooth Count50 / 34 Material7075 T6 aluminum Bolt Circle Diameter110 mm (compact) Detail Extralite R oad C...
$200.002 in stock.View
Specifications Weight 135g Sizes 50/34t BCD 110mm BCD Colors Anodized Blue and Black Anodized Bronze and Black Anodized Gold and Black...
$130.00 $97.50Save: $32.50 off
1 options.View
Specifications Weight 129g Sizes 44t/32t, 22t BCD, 44t/32t 104mm BCD BCD, 22t 64mm BCD Bold Pattern 4 Bolt Pattern Colors Anodized Blue...
$145.00 $108.75Save: $36.25 off
2 options.View
Specifications Weight 150g Sizes 53/39t BCD 130mm BCD Colors Anodized Blue & Black Anodized Bronze & Black Anodized Gold...
2 options.View
Fibre-Lyte carbon fiber chainrings are available as a single ring for time trial racing for which they can last thousands of miles if...
$130.0015 options.View
Specifications Weight, 38t 23g Weight, 39t 23g Weight, 50t 54g Weight, 53t 54g Sizes 38t, 39t, 50t, 53t Details Fibre-Lyte carbon fiber...
$130.0011 options.View
Closeout - 50% Discount Specifications Weight, 22 tooth 17 grams Weight, 29 tooth 20 grams Weight, 32 tooth 33 grams Weight,...
$60.00 $30.00Save: $30.00 off
11 options.View
Closeout - 50% Discount Specifications Weight, 34 t - 110 BCD 30 grams Weight, 50 t - 110 BCD 85 grams Weight, 39 t - 130 BCD 39...
6 options.View
Specifications Weight 10 grams Details KCNC chainring bolts for Campagnolo Ultra Torque cranksets. These KCNC Chainring bolts are specific to...
$22.006 options.View
Specifications Weight 10 grams Details Anodized 7075 aluminum chainring bolts. Laser-etched with the KCNC logo. Includes five standard...
$16.006 options.View
Specifications Weight, 64 BCD 24t19 grams Weight, 64 BCD 26t23 grams Weight, 64 BCD 27t25 grams Weight, 64 BCD 29t26 grams Weight, 64 BCD 30t28...
$46.0011 options.View
Specifications Weight, 110 BCD 34t30 grams Weight, 110 BCD 50t82 grams Weight, 110 BCD 39t33 grams Weight, 110 BCD 53t71 grams Weight, 130 BCD 39t33...
$55.0010 options.View
Specifications Weight - 22t/24t 18 grams Weight - 32t/34t 34 grams Weight - 44t 87 grams Material 7075 aluminum Detail A...
$30.007 options.View
Specifications Weight - 34t 33 grams Weight - 50t 100 grams Weight - 39t 40 grams Weight - 53t 88 grams Material 7075...
$44.004 options.View
Specifications Weight 7.5 grams/set Material 7075 aluminum Details KCNC's single speed chainring bolts offer an affordable and attractive means...
Specifications Weight, 39 tooth32 grams Weight, 53 tooth95 grams Weight, 34 tooth28 grams Weight, 50 tooth92 grams Materialforged 7075 T6 aluminum...
$160.003 options.View
Closeout - Colored Chainrings 25% Discount Specifications Weight, 38 Tooth32 grams Weight, 39 Tooth32 grams Weight, 42 Tooth35 grams Weight, 50...
6 options.View
Specifications Weight, 39 Tooth33 grams Weight, 53 Tooth82 grams BCDCampagnolo 135 Material7076 T6 aluminum Finshmatte grey Compatible...
$72.002 options.View
Specifications Weight, 39 Tooth32 grams Weight, 42 Tooth35 grams Weight, 50 Tooth78 grams Weight, 53 Tooth89 grams Material7075 T6 aluminum...
$60.005 options.View
Specifications Weight, 34 Tooth30 grams Weight, 36 Tooth39 grams Weight, 50 Tooth75 grams BCDCampagnolo compact 110 Material7076 T6 aluminum...
$68.003 options.View
Specifications Weight 50t, 75g 36t, 33g Sizes 36T and 50T Colors Matte Silver Details TA Specialties manufactures high quality...
$65.003 options.View
Specifications Weight 90g Sizes 52T, 53T Colors Polished Silver Details TA Specialties manufactures high quality aftermarket aluminum...
$160.002 options.View
Specifications Weight 34t, 31g 36t, 35g 50t, 85g Sizes 34T, 36T, 50T Colors Black Details TA Specialties manufactures high quality...
Specifications Weight, 34 tooth 34 grams Weight, 36 tooth 35 grams Weight, 39 tooth 32 grams Weight, 50 tooth 79 grams Weight, 53 tooth 82...
$75.005 options.View
