Cane Creek AER Headset
Cane Creek AER Headset 1 1/8" IS Integrated$100.00  2 Remaining
Cane Creek AER Headset 1 1/8" Traditional$125.00  2 Remaining
Cane Creek AER Headset 1 1/8" ZS$125.00  1 Remaining
Cane Creek AER Headset Replacement Norglide Bearing$20.00  2 Remaining
Traditional
Weight46 grams
Top Stack Height7.90 mm
Bottom Stack Height12.05 mm
Material7075 T6 aluminum
Top BearingNorglide X2 Composite Bearing
Bottom BearingSplit-Lip Black Oxide
IS
Weight33 grams
Top Stack Height8.0 mm
Bottom Stack Height4.5 mm
ZS
Weight52 grams
Top Stack Height5.2 mm
Bottom Stack Height1.0 mm
The AER headset from Cane Creek is one of the world's lightest headsets. The AER features what Cane Creek calls a "norglide composite bearing" used as the upper bearing, essentially a plastic plate with a low friction interface. The norglide composite is an intriguing approach to save additional weight.
For the traditional version, the headset cup skirts that insert into the headtube are of a hollowed "window" design, shaving additional grams without sacrificing functionality.
These AER headsets are of the standard threadless design, for use with 1 1/8" steerer tubes.
Installation/Assembly
These Cane Creek headsets require specialized headset installation tools. We recommend that these be professionally installed to avoid damage to the headset, frame, or fork.
Note: Cane Creek recommends that the upper Norglide bearing be replaced after 2,000 - 3,000 miles of riding.
