Cane Creek AER Headset Spacer
Size1-1/8"
MaterialAluminum Alloy
Weight
5mm2g
10mm3.7g
Cane Creek AER Headset Spacer 5mm $11.00 In Stock
Cane Creek AER Headset Spacer 10mm $12.00 In Stock
Details
The AER headset spacer features an interlocking design that stacks the spacers together neatly with each other. Cane Creak claims that this interlocking design allows for the spacers to act as one and eliminates any creeking noise that might occur as standard headset spacers rub together. The cut out on the sides gives the spacer a very unique design and reduces its weight significantly. The spacer works perfectly with any headset on the market although it is designed around and aesthetically matches the AER Headset.
Comment on Cane Creek AER Headset Spacer
