Cables & Housing
Alligator iLink Cable System
Alligator iLink Ultralight cable systems are 50% lighter than conventional cables, and feature a polymer liner that greatly reduces friction between...
$60.00
10 options.View
Ashima Reaction Brake cable/housing kit
Specifications FitsShimano, Sram, CampagnoloStylesRoad brake or derailleurColorTransparent black Detail Ashima Reaction Brake cable and housing kit....
$40.00
8 options.View
Ashima Reaction Shifter cable/housing kit
$40.00
8 options.View
Far and Near Cable Tips
Package of 25 cable end caps. Black, Blue, Gold, Green, Purple and Red. Fits either brake or shift cables.
$7.00
6 options.View
Far and Near Ferrules 4mm
Far and Near's anodized ferrules give you yet another way to add a little bit of style to your bike. These ferrules are CNC machined from aluminum,...
$10.00
4 options.View
Far and Near Ferrules 5mm
$10.00
4 options.View
Far and Near Housing Covers
Specifications Weight 1.7 grams each Housing Compatibility 4 mm, 5mm Available Colors black, blue, celeste, red, white, yellow Detail These...
$8.00
7 options.View
Gore RideOn Professional Cable System
Specifications Housing Diameter 4 mm Housing Length 2050 mm Front Cable Length 1900 mm Rear Cable Length 2200 mm Detail Designed...
$65.00
2 options.View
Gore RideOn Sealed Low Friction System
Details These cables are ideally suited to mountain and cyclocross bikes, cables are completely protected from mud, dirt and the elements via...
$65.00
4 options.View
KCNC DLC Derailleur Cable
Specifications Weight14 gramsMaterialstainless steelCoatingNano-Diamond TeflonLength2100 mmDiameter1.1 mm Detail KCNC has made a dramatic improvement...
$30.00
12 in stock.View
KCNC DLC Mountain Brake Cable
Specifications Weight24 gramsMaterialstainless steelCoatingNano-Diamond TeflonLength1700 mmDiameter1.5 mm Detail KCNC has made a dramatic improvement...
$25.00
18 in stock.View
KCNC DLC Road Brake Cable
$25.00
8 in stock.View
KCNC Ferrules
Specifications Material7050 AlloyColorsBlack, Blue, Gold, Green, RedSize4mm, 5mmPackage contains150 ferrules Detail Kcnc aluminum ferrules, stronger...
$110.00
10 options.View
KCNC Teflon Derailleur Cable
Specifications Cable Material:Stainless SteelCoating:TeflonColors:Blue, Green, Orange, Pink, Red, WhiteLength:2100mmDiameter:1.1mmWeight:14.5 grams...
$7.00
6 options.View
KCNC Teflon Mountain Brake Cable
Specifications Weight24 gramsMaterialstainless steelCoatingNano-Diamond TeflonLength1700 mmDiameter1.5 mm Detail KCNC's coated cables begin life as a...
$7.00
4 options.View
KCNC Teflon Road Brake Cable
Specifications Cable Material:Stainless SteelCoating:TeflonColors:Blue, Green, Orange, Pink, Red, WhiteLength:1700mmDiameter:1.5mmWeight:20 grams...
$7.00
6 options.View
Nokon Alloy MTB Brake Housing
Specifications Weight 36g per meter (housing and liner) Colors Black and White Details Nokon aluminum housing systems provide a superior...
$84.00  $67.20
Save: $16.80 off
1 options.View
Nokon Alloy MTB Shift Housing
Specifications Weight 40g per meter (housing and liner) Colors Black, Blue, Gold, Red Details Nokon aluminum housing systems provide a...
$93.00  $74.40
Save: $18.60 off
2 options.View
Nokon Alloy Shift Housing for Campagnolo/Sram
Specifications Weight 40g per meter (housing and liner) Colors Black, Blue, Gold, Red, Silver, White Details Nokon aluminum housing systems...
$93.00  $74.40
Save: $18.60 off
1 options.View
Nokon Alloy Shift Housing for Shimano
$93.00  $74.40
Save: $18.60 off
2 options.View
Nokon Carbon Shift Housing
Specifications Weight 32g per meter (housing and liner) Details Complete set of housing sections, liners, and stainless steel shift cables for...
$267.00  $213.60
Save: $53.40 off
2 options.View
Nokon Housing Extension Kit
Specifications Weight 40g per meter Details This 42 piece Nokon extension kit includes liners and black anodized housing sections to extend...
$27.00  $18.90
Save: $8.10 off
2 options.View
Power Cordz 5 mm Housing Segment
Specifications Weight38 grams per meterLength1 meterOuter Diameter5 mm Detail This housing segment is provided by Power Cordz as an extension to...
$10.00
1 in stock.View
Power Cordz Brake Cable Set
Closeout - Colored MTB Brake Cordz 20% Discount! Specifications Weight 5 grams per cable Colors black, blue, red, white, yellow Diameter 1.75...
$37.00  $29.60
Save: $7.40 off
7 options.View
Power Cordz Brake System Prime
Specifications Weight, complete mountain system95 gramsWeight, complete road system85 grams Contents 2 ea - 1.75mm brake Cordz 1 ea - pre-lubed 5mm...
$79.00
4 options.View
Power Cordz Derailleur Cable Set
Closeout - 1.5 mm Derailleur Cordz 20% Discount! Specifications Weight, 1.2 mm5.3 grams/pairWeight, 1.5 mm8.2 grams/pairLength2 meters Detail...
$37.00  $29.60
Save: $7.40 off
8 options.View
Power Cordz Derailleur System
Closeout - 5 mm Derailleur System 20% Discount! Details Experience the next generation of cycling cable control systems! IoDupont's Power Cordz...
$68.00  $54.40
Save: $13.60 off
4 options.View
Power Cordz Nokon Liner
Contains 3 - two meter long sections of liner Details Until recently, it was not possible to use PowerCordz brake cables with Nokon housing systems....
$12.00
0 in stock.View
Power Cordz Windsor Brake Clasps
Specifications Weight 2.0 grams per pair Compatibility (5mm, 6mm) All Campagnolo and SRAM Force brake calipers, as well as many aftermarket...
$11.00
3 options.View
Yokozuna Reaction Shift and Brake Cable Set
Details Yokozuna Reaction cable and housing kits' proprietary casing designs have greatly improved cable life and performance. Compression-free cable...
$60.00
3 options.View
