Skip to content
Titus Di2 Project 29er
Viewing 15 posts - 1 through 15 (of 24 total)
  • #93001
    Keymaster
    The buildup to Interbike has been both long and hectic for us, but we are totally thrilled with the result of our first project, the Titus Project-29.  This is not only the next step of the mountain Di2 project we started almost 2 years ago, but has countless applications for the road group as well.  A programmable Di2 brain that in this setup uses a single shifter with multiple modes including both sequential shifting of front and rear derailleurs together as well as the ability to manually shift either derailleur independently.
    The – new – Di2 Brain
    The central part of the project is this little “brain” that makes virtually anything possible.   This was designed and built for us by forum member jeffr (Jeff Roberson.)  Jeff’s resume is really very impressive and we are completely honored that he undertook this project fabricating everything we wanted and then so much more.  We can’t express our gratitude to him enough.  This little board, a proof of concept, that he built not only takes Di2 to the next level, but kicks open countless doors for the future.
    Component and Build Description
    We started with a custom Titanium hardtail frame from Titus.  Then we added a modified Cannondale Carbon Lefty fork.  For the wheels we used the sub 950 gram tubular set that we showed earlier this year(Edge tubulars, Tune Cannonball/Dezibel and Pillar spokes)  Dugast tires were added to the wheels to finish them off.  For the brakes we went with Kcnc’s new X7 disc brake system but added in some Scrub Race Day rotors to cut the weight even further. We used a whole host of other Kcnc parts such as the Morion ceramic headset and their hollow headset spacers. We also used the new double chainring K2 type cranks from Kcnc. Other Kcnc products on the bike were the bar end plugs, skewers, valve extenders, grips, seat collar, Ti DLC Knife pedals and Ti pro lite seatpost as well as a mix of Kcnc tuning parts to color and lighten the rear derailleur. A custom Edge (now known as Enve) stem had to be made to house the brain, and a pair of Edge/Enve sweep bars were mated to that. The bike was finished off with a Tune Kom Vor saddle and Tune’s new bottle cage.
    The finished bike weight tipped the scales right at 16 pounds.
    At first glance the bike appears to be pretty straight forward, much like last years Di2 mountain bike.  Notably absent however is the battery, which this year was placed inside the seat tube.   The most important missing piece though happens to be the left shifter.  In it’s current mode the shifting is done via the single right shifter.  Although potentially limitless we’ll describe two shifting setting currently programmed into the brain.
    Complete Bike Build
    Automatic Mode
    Two buttons, one for an up shift and one for a down shift.  The brain basically uses calculated gear inches to decide on the proper next gear.  It’s not as simple as a linear list though.  The bike does not just run back and forth through pre-set options.  It is configured to remove duplicate gears as well as cross chaining.  But more importantly it reduces the amount of front chainring shifts it makes.  If you are in your small ring and reach a point where it needs to shift the front to get a higher gear it does that.  But then if you shift back to a smaller gear it does not return the chain to the small ring with the next down shift.  It knows there are other options to get that same gear by staying in the larger ring and as long as one of those options does not create a bad chainline it will go for one of those.  That means in moving from the lowest gear on the bike to the highest it only needs to shift the front derailleur once.
    Manual Shift Mode
    There are also other modes available such as a manual shift mode.  In a manual mode the right shifter buttons independently move the rear derailleur up and down as they would in a normal Di2 setup.  To shift the front derailleur both buttons are pushed at the same time.  Since the bike is a double up front there is no need to tell it what direction to shift in manual mode, but only to shift to where it currently does not reside.
    Other Shift Features
    One other nice feature that Jeff built into this brain is the ability to dump gears.  As a further improvement gears can be dumped as many as 13 at a time and in either the up or down direction.  He opted to slow this dumping from it’s full potential speed in to reduce the chance of dropping a chain.  However, even in this slowed down mode it can go from the highest gear on the bike, a 42/11, to the lowest gear on the bike, a 29/32, in just over 1 second and without having to soft pedal.
    There are also other modes which will eventually be mentioned.  Jeff, when asked, simply replied, “if you can think of it, it can probably do it.”
    #93002
    Brian
    OK – how about this formula – (Di2) + (ANT+ power meter) = automatic transmission. Could be done, right?
    #93003
    Participant
    Has that Kom-Vor been altered in any way? It looks like there is less material in the nose piece than on mine
    #93004
    Keymaster
    @Brian, Now your getting into the stuff that we think is really exciting about the concept this bike proves. Once you add in Heart Rate, Cadence, Power, Elevation, some fuzzy logic (or learnt shifting) this could get very very cool.
    @Jacob, Completely stock. Camera takes away ten pounds… or something like that.
    #93005
    Participant
    Automatic transmission is quite a concept
    #93006
    Rob Allen
    Do you guys think you could use this system (Di2/Disc brakes) on a cyclocross bike?
    #93007
    Brian
    Yeah, conceptually it’s really intriguing. I don’t know if I’d want to ride such a bike on trails (I don’t even drive an AT car, btw), but it could mean seconds to a time-trialist if you could dial in a power profile for a particular course and just leave the levers alone. That has “UCI Sanctions” written all over it, doesn’t it?
    #93008
    Johnny
    It looks like some people are misinterpreting what is meant by “Automatic” mode. Read the description. The bike isn’t picking what gear you’re in, it’s picking how you’re in that gear. Instead of selecting a front and rear gear, all the rider does is push the button for an easier/harder gear and the drivetrain will automatically pick the correct front/rear combo. This system eliminates overlapping ratios.
    #93009
    Keymaster
    @Brian,
    It all sounds really fun. We can’t wait to see where this goes. I think it will have it’s place but obviously will not be for everyone or every situation. Who knows what the UCI will think of it. Maybe they’ll let someone win a world championship on it then outlaw it on the eve of a semi-important race after teams spent all winter developing and testing on it. :)
    #93010
    Brian
    @Johnny – We do understand the build. What we’re talking about is the potential for adding a couple other inputs like speed, cadence, or power and then writing automatic transmission software.
    #93011
    Participant
    The custom job done on this is insane. I would love the sequential shifting on the road bike but in reality unless you are riding a VERY hilly up and down race you’ll more than likely not need it. If you incorporated the other feed in parameters I would want a kill switch on the automatic shifting. Some days you are just not going to want ride the gear you have pre-programmed in. I’ll be watching with interest.
    Now that you guys are back from Interbike. Is there any thoughts on making the MTB sequential shift ‘kit’ or at least the brains with modification instructions available for purchase? I am sure you were asked a million times at the show.
    #93012
    Keymaster
    @Sean,
    Glad you like it… Yes, manual overrides or a “kill switch” will be needed.
    The kit is more than likely never going to happen. There’s some lawyer issues that are better left to lawyers. There is the immeasurable costs from Jeff… Small to tiny market etc. We will make sure to ride this one though! :)
    #93013
    Participant
    Ahh! Lawyers. Enough said.
    #93014
    Glenn
    I can appreciate the lawyer garbage, but if you simply publish the information on the sequential shifting and people make it for themselves, you could never be held liable . . .
    However, it all sounds great. It is always great to see people extend themselves!!!
    #93015
    Berg
    Just one question: Where can I buy one?
    Nice!!!
