Brakes (Mtb)
Ashima AI Stainless Steel Rotor
Specifications MaterialStainless Steel FitsISO, 6 bolt Sizes140, 160, 180, 185, 203 Weights140-68gr, 160-85gr, 180-112gr, 185-113gr, 203-136gr...
$30.00
18 options.View
Ashima Disc Brake Adapters
Specifications Weight, AU0122 grams w/bolts Weight, AU0227 grams w/bolts AU01 Fitfront: IS fork, PM caliper, 160mm rotor rear: IS frame, PM caliper,...
$12.00
2 options.View
Extralite Ti Rotor Bolts
Specifications Weight 5 grams Details Disc rotor bolt set, includes 6 pieces. GRD5 Titanium.
$45.00
0 in stock.View
Extralite Ultra Brake
Specifications Weight 99 grams/set Details Four sealed ball bearings ensure a constant position of return springs. Return springs are made with...
$198.00
0 in stock.View
Extralite Ultra Levers
Specifications Weight 64 grams/set Material Ergal 7075TX Construction hyper accurate CNC. Compatibility Grip and Trigger shifters Tuning...
$198.00
1 in stock.View
Far and Near Disc Brake Rotor
Specifications Weight, 160 mm114 grams Weight, 180 mm129 grams
$50.00  $35.00
Save: $15.00 off
10 options.View
Far and Near Titanium Rotor Bolts
Specifications Weight per Set ~14 grams Bolt Thread M5 x 10 mm Details This lightweight titanium rotor bolt set from Far and Near includes 12...
$50.00
5 in stock.View
KCNC 7075 Cantilever Brake Set
Specifications Weight, Complete Set250 grams Weight, Caliper Pair w/Pads80 grams Weight, Fork Housing Stop38 grams Weight, Seatpost Collar18 grams...
$300.00
0 in stock.View
KCNC Centerlock Adapter
Specifications Weight29 grams Material6061 aluminum Detail These centerlock adapters from KCNC are designed to allow the use of standard ISO 6-bolt...
$45.00
5 options.View
KCNC Razor Disc Brake Rotor
Specifications Weight, 140 mm62 grams Weight, 160 mm74 grams Weight, 180 mm95 grams Materialstainless steel Detail Razor rotors push the limits of...
$25.00
3 options.View
KCNC Rotor by Ashima
Specifications Weights 85 grams, 105 grams, 130 grams Available Diameters 160 mm, 180 mm, 203 mm Detail KCNC disc brake rotors, manufactured...
$25.00
1 options.View
KCNC V-Brake Pad Holders
Specifications Weight 33 grams Cartridge Brake Shoe Set 72mm Construction M7 scandium alloy Bolts Compatibility XT, XTR, KCNC VB1, and most...
$33.00
1 in stock.View
KCNC V6 Linear Pull Brake Set
Specifications Weight, Complete Set 312 grams Weight, Calipers 123 grams Weight, Lever Set 66 grams Vertical Pad Reach 15-40 mm Acceptable...
$290.00
6 options.View
KCNC VB1 Brake Lever Set
Specifications Weight per Pair48 grams Material7075 aluminum Lever End to Pivot92 mm Bar Clamp Diameter22.2 mm Detail KCNC's VB1 brake levers are...
$140.00
0 in stock.View
New Ultimate Disc Brake Rotor
Specifications Weight (without bolts) 80 grams Bolt Pattern 6-bolt ISO Diameter 160 mm Bolt Pattern 6-bolt ISO Detail The material of...
$40.00  $30.00
Save: $10.00 off
3 in stock.View
Scrub Disc Brake Pads
Detail The material in these pads is specifically tested and designed for use with the proprietary metal material used in Scrub rotors. These pads...
$28.00
6 options.View
Scrub RaceDay Rotor
Specifications Weight 49 grams each Size 160 mm Detail The Scrub RaceDay is designed for the demands of mountain bike racing. The materials in...
$215.00
4 options.View
Scrub Workhorse Rotor
Specifications Weight, 140 mm43 grams Weight, 160 mm58 grams Available Colorsblack, blue, green, red, white Detail Scrub's Workhorse Rotors are at...
$145.00
8 options.View
Swiss Stop "Rat" Pads (for post-style cantilevers)
Swiss Stop's Rat series brake shoes are compatible with post-style cantilever brakes, common on cyclocross bikes and older mountain bikes. These are...
$26.00
3 options.View
Swiss Stop "RX" Pads (for V-brake cartridges)
Swiss Stop's RX series brake pads are compatible with most linear pull style brake shoe cartridges. These are available in two different compounds...
$24.00
2 options.View
Swiss Stop Disc Brake Pads
Disc brake pads from Swiss Stop are manufactured with a compound containing a ceramic/Kevlar/brass/resin. This unique formulation gives you the feel...
$28.00
7 options.View
Swiss Stop Disc Brake Silencer
Detail Swiss Stop's Disc Brake Silencer is a metallic based aerosol spray treatment designed for both metallic and organic disc brake pads. True to...
$32.00
4 in stock.View
Swiss Stop Viking Brake Pads (for threaded post cantilevers)
Swiss Stop's Viking series brake shoes are compatible with newer style cantilever brakes, which require pad holders with a threaded post. These are...
$27.00
2 options.View
