Brakes (Mtb)
Detail Designed in the U.K. and manufactured by Ashima in Taiwan, the rotors are available in 140mm, 160mm, 180mm, 185mm and 203mm diameters. Ashima...
19 options.View
For cross country applications, the Ashima Ai2 rotor is one of the lightest weight options. Ashima achieves their svelte design by way of aggressive...
2 options.View
Detail Ashima's aluminum rotor bolts have been specially designed with the specific properties of the aluminum material in mind. Traditionally,...
3 options.View
Ashima’s Centra-Lite adapters allow the use of standard ISO six bolt rotors to be used on Shimano and DT-Swiss centerlock specific hubs. With fewer...
0 in stock.View
Detail These Ashima disc brake adapters are designed to allow Post Mount (PM) calipers to attach to International Standard (IS) frame and fork tabs....
2 options.View
Ashima's steel rotor bolts offer color options as a substitute for ordinary silver rotor bolts, sans logos. Ashima rotor bolts are to be installed...
4 options.View
Extralite's Titanium rotor bolts make alightweight replacement for stock rotor bolts. As with all rotor bolts we recommend using a thread prep such...
0 in stock.View
Extralite has manufactured one of the premier disc brakes of all time. If this was the era of V-brakes the Extralitewould be one ofthe most popular...
2 in stock.View
Lightweight, strong, and stylish, these are the levers to have! One finger or two you'll feel a perfect pulling ratio.
1 in stock.View
This lightweight titanium rotor bolt set from Far and Near includes 12 bolts, a complete package for a pair of standard 6 bolt rotors. The average...
1 in stock.View
Detail KCNC's heavily CNC machined cantilever brakeset is the absolute lightest-weight brakeset available for cyclocross bikes. Drawing from the...
2 options.View
Detail These centerlock adapters from KCNC are designed to allow the use of standard ISO 6-bolt rotors with DT Swiss and Shimano centerlock hubs....
5 options.View
Detail Razor rotors push the limits of what a stainless steel rotor can be. By utilizing such a common and reliable material, KCNC has created an...
3 options.View
Detail KCNC disc brake rotors, manufactured by Ashima, are available in 160mm, 180mm, 203mm (8") diameters. Ashima rotors are manufactured to be...
1 options.View
KCNC's V-brake pad holdersare a simple and elegantreplacement or lightweight upgrade for your brakes. The minimal skeleton is ultra light and comes...
1 in stock.View
Detail KCNC's complete linear pull brake set is, if nothing else, a testament to their machining prowess. Each individual 6061 aluminum component of...
6 options.View
Detail KCNC's VB1 brake levers are minimally designed and meticulously CNC machined in order to achieve the lowest possible weight. This design...
2 in stock.View
Detail The material of choice for New Ultimate's disc brake rotors is durable and inexpensive steel. While this material is normally reserved for...
0 in stock.View
Detail The material in these pads is specifically tested and designed for use with the proprietary metal material used in Scrub rotors. These pads...
6 options.View
Detail The Scrub RaceDay is designed forthe demands of mountain bike racing. The materials in this rotor allow for heat transfer that is 7 times more...
4 options.View
Detail Scrub's Workhorse Rotors are at once lightweight, durable, and functionally sound. Scrub Components developed a proprietary metal matrix...
8 options.View
Disc brake pads from Swiss Stop are manufactured with a compound containing a ceramic/Kevlar/brass/resin. This unique formulation gives you the feel...
7 options.View
Detail Swiss Stop's Disc Brake Silencer is a metallic based aerosol spray treatment designed for both metallic and organic disc brake pads. True to...
3 in stock.View
Closeout - 25% Discount Swiss Stop's Rat series brake shoes are compatible with post-style cantilever brakes, common on cyclocross bikes and older...
3 options.View
Swiss Stop's RX series brake pads are compatible with most linear pull style brake shoe cartridges. These are available in two different compounds...
2 options.View
Swiss Stop's Viking series brake shoes are compatible with newer style cantilever brakes, which require pad holders with a threaded post. These are...
2 options.View
