Bottom Brackets
Chris King Bottom Bracket
Specifications Weight102 gramsThreadEnglish (BSA, 1.375" x 26 tpi)BearingKing Stainless SteelCompatibilityShimano HTII, Sram and Truvativ GXP, FSA,...
$135.00
10 options.View
Chris King Ceramic Road Bottom Bracket
Specifications Weight99 gramsThreadEnglish (BSA, 1.375" x 26 tpi)BearingKing Hybrid SS/CeramicCompatibilityShimano HTII, Sram and Truvativ GXP, FSA,...
$199.00
2 options.View
HSC BB30 Ceramic Adapter Bottom Bracket
Specifications Weight45 gramsBearings6805w7 (2) Si3N4 Ceramic hybridCup MaterialaluminumShell CompatibilityBB30 (68mm wide, 42 mm ID)Crankset...
$120.00
10 in stock.View
HSC BB30 Ceramic Bottom Bracket Kit
Specifications Fits:All BB30Weight:54gramsBearing:Si3N4 Ceramic hybrid Detail HSC Ceramic bearing bottom bracket for BB30 One of the smoothest and...
$140.00
10 in stock.View
HSC BB30 Reducer Sleeves
Specifications Weight44 gramsMaterialdelrin thermoplasticBB CompatibilityBB30, PF30Crankset CompatibilityShimano Hollowtech II Detail Shimano is one...
$50.00
2 in stock.View
HSC Ceramic BB86 Bottom Bracket
Specifications Weight54 gramsBearings6805w7 (2) Si3N4 Ceramic hybridCup Materialdelrin thermoplasticShell Compatibility86.5 mm wide, 41 mm IDCrankset...
$120.00
6 in stock.View
HSC External Road Bottom Bracket
Specifications Weight84 gramsBearings6805 Si3N4 Ceramic hybridAvailable Threading1.37" x 24 tpi (English, BSA) 36 mm x 24 tpi (Italian)Crankset...
$110.00
8 options.View
HSC PF30 Ceramic Bottom Bracket Kit
Specifications Weight74 gramsBearings6806 (2) Si3N4 Ceramic hybridCup Materialdelrin thermoplasticShell Compatibility68 and 73 mm wide PF30 Detail...
$120.00
13 in stock.View
KCNC BB30 Mountain Adapter Bottom Bracket
Specifications Weight 118 grams Bearing Size 6805 (2) Use road, cross country Detail These bottom brackets from KCNC are designed to adapt...
$40.00
1 options.View
KCNC BB30 Road Adapter Bottom Bracket
$40.00
3 options.View
KCNC BB86 Adapter
Specifications Weight92 gramsCrankset CompatibilityShimano Hollowtech II, KCNC K-TypeBearing Size6805 w7 (2)Material6061 T6 aluminum Detail BB86 is a...
$40.00
0 in stock.View
KCNC PF BB41 Mountain Bottom Bracket
Specifications Weight95 gramsBB Shell Fit, Inner Diameter41 mmBB Shell Fit, Width89.5, 92.0 mmCrankset CompatibilityShimano Hollowtech II, KCNC...
$40.00
0 in stock.View
KCNC Roller Bearing Bottom Bracket
Specifications Weight 128 grams Material 6061 Al Details KCNC's roller bearing bottom bracket is designed for intensive and heavy-duty usage....
$60.00
2 options.View
Parlee BB30 Shimano HTII Adapter Bottom Bracket
Specifications Weight102 gramsCrankset CompatibilityShimano HTIIBearing Size2437 (2) Detail This bottom bracket adapter is supplied by Parlee to...
$65.00
0 in stock.View
THM Clavicula BB30 Bottom Bracket
Detail These BB30 adapter bearing cups are designed for use with THM's line of Clavicula cranksets. Compatible bottom bracket shells will be 68 mm...
$150.00
2 options.View
Tune Smartfoot Bottom Bracket
Specifications Weight, BB30 68/7358 gramsWeight, BSA 68/7392 gramsBearingssteel cartridge, 6806 (2) Detail These bottom bracket bearing kits are...
$70.00
2 options.View
